Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 161 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd November 2013, 05:05 AM   #1601
pidesd is offline pidesd  Canada
pidesd's Avatar
hi guys,
is there any reason why this topology would not work well? for a lower input impedance...
edit: maybe the circuit is not right as the gates are not reference to ground...now is bed time
Old 23rd November 2013, 07:35 AM   #1602
EUVL is offline EUVL  Europe
Yes, no Gnd (or Vref) reference for the gates.
See Moving Coil Cartridge Head Amps
The minute you have that Gnd reference, you have current flowing through from floating supply to Gnd.
So the two current loops are no longer totally separate.
Not the case with JFET, since no gate current, and no biasing resistor network necessary.
Patrick
xen-audio.com
Old 27th November 2013, 06:03 PM   #1603
pidesd's Avatar
Default for d1 lovers
Old 13th December 2013, 01:31 PM   #1604
pinnocchio's Avatar
Since there are so many pages, can anyone point me to the discussion (if any) to adapt the cen/sen I/V to the BII/BIIISE?
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA2 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 16th December 2013, 10:32 PM   #1605
alazira is offline alazira  United States
alazira's Avatar
Nicmac discusses his build here:
Old 8th January 2014, 01:49 PM   #1606
if i'm going to use 2sk117 for cen, what would the p channel equivalent to sj74 be?
Old 8th January 2014, 07:47 PM   #1607
No p-channel equivalent. You need to use SEN.
Patrick
xen-audio.com
Old 9th January 2014, 01:52 AM   #1608
Can i still use sk117 for sen?
Id be happy as long as it works
170 is hard to source in asia
Old 11th January 2014, 01:59 PM   #1609
Read the article.
Patrick
xen-audio.com
Old 18th January 2014, 12:53 AM   #1610
The origin of this circuit, as mentioned in the article, was Dr. Leach's MC headamp.
The natural question arises as to whether we could use the JFET version for the same purpose.
This is being discussed independently, as I found out by chance, elsewhere :
audio-talk :: View topic - j-FET / Triode Phono front-end
(see post by JamesD on Mon Oct 07, 2013 8:26 pm)
As you would expect, we did consider this application for ourselves.
The biggest problem is DC offset.
If the Idss of the JFETs do not match and thermally track perfectly all time during operation, 2 things will occur :
1) A DC offset will be seen by the MC pickup at the input, causing a small DC current.
2) This current has to pass through R1 and/or R2, thus causing imbalance of the Vds of the two FETs.
This has been verified in Spice (I am not prepared to risk my MC pickup for that).
The second point above can be solved by replacing R2 by a Zener diode, but this does not solve the DC current problem.
To improve thermal tracking, one can :
a) use a monolithic dual JFET such as LSK389 or 2SK2145;
b) degenrate the JFET to the appropriate Zin for the MC, which also improves Id stability.
But we are trying to limit DC current to µA level, when the JFET bias is ~8mA.
In the Leach circuit, he was using 125µA bias and this was also done by a resistor network.
So there is a chance of better thermal stability.
Patrick
xen-audio.com
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 06:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 12:57 PM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 05:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 04:36 PM
Copyright ©1999-2017 diyAudio
