Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 158 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th October 2013, 06:14 PM   #1571
Joachim Gerhard's Avatar
Please publish your questions about Nobrainer on the Nobrainer thread and i answer.
About know how : I had hoped that people are learning when they are building.
Old 19th October 2013, 06:31 PM   #1572
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
When I told you I needed your input, I already had published my question on the nobrainer thread... this was just a reminder hoping you would care to answer.
I see no point in building stuff if I do not fully understand the basics. Off course I learn by building... I did not study electronics in the university... I followed maths and if someone asks for my help I will always try to make it clear taking in consideration their flaws in algebra.... it is not possible to know everything all the time but we can always help if we want.
I do not think electronics to be an unreachable matter, I just need some hints here and there.
And most of all, I do not think those who learned how to design circuits to be more intelligent than others that learned how to design bridges.... can not grasp your bitterness.
RC
Old 19th October 2013, 06:47 PM   #1573
The problem is that some here want to build the best with minimal outlay but they are not willing to study the circuit.
For example this problem with noise from the degenerated Fet.
It is the same then the noise contribution from the mirrors in the Paradise.
The higher the degeneration, the less is the CURRENT noise that is injected in the circuit.
That has being discussed and explained many time at least in my thread so i expect that somebody that reads the thread also reads the explanation.
I for one tried very hard to explain what i did.
That seems obviously ( more or less often ) not to be the case. Picking out the cherries is easy.
So how can there be even a basic understanding ? When it comes to pick expensive or exotic components then it gets into very different territory. Everybody seems to be an expert on this up to real hard core opinion.
I do not talk about you particular, Ricardo, you contributed even with optimizing the RIAA components and yes, my ability to design circuits makes me not more or less intelligent then somebody else that does other things better then me.
Old 19th October 2013, 06:54 PM   #1574
nhinstruments
RCruz's Avatar
I am sorry I did not have the opportunity to follow your thread completely and so missed some important pints.
Anyway you made it very clear now and I see that Voltage noise increases with resistance and current noise decreases. For example, if you have a current mirror, and you wish the output to have low current noise you would be safe with a large resistor on the input side, since its current noise will be low. This large resistor will contribute a low amount of noise to the input, and thus the only noise you are left with at the output is the noise intrinsic to the current mirror itself.
As you see I am a fast learner.... just need some patience.
And I want to study the circuits and fully understand those before I adventure in building.
RC
Old 19th October 2013, 07:23 PM   #1575
In the Paradise we found that the emitter resistors ( you call it input resistor, that are the resistors that go to the PSU ) should be more the 100 Ohm. Making them bigger then say 200 Ohm does not make a big difference any more. That resistor also has an effect on the output impedance of the mirror. Higher is better but there is also the issue of thermal drift so a compromise has to be found. I think that thoughts went into the current injecting Fet too and one that can be degenerated more to give the desired current is better when we bias that Fet into a region where it has a neutral drift.
Old 19th October 2013, 08:09 PM   #1576
smms73 is offline smms73  Portugal
smms73's Avatar
Ricardo, I will send you a email explaining , in Portuguese.
Sérgio Santos
Old 20th October 2013, 09:56 AM   #1577
nhinstruments
RCruz's Avatar
Yes, now I understand why the current injecting fets where so degenerated.
Also clearly understand the compromise choosing the 120r on the mirrors emitters.
I guess the source resistors in the output buffer serve the same purpose.
RC
Old 20th October 2013, 09:56 AM   #1578
nhinstruments
RCruz's Avatar
Thank you Sergio... looking forward to it.
RC
Old 31st October 2013, 03:27 PM   #1579
heb1001 is offline heb1001  China
Default PCM1794A
This is where I ended up with my Sen variant #998 (with 0R for RM) for PCM1794A described above:
Analyzing "mysensample.flac"...
Frequency: 999.977933 Hz
THD+N: 0.0009% or -101.3 dB
This THD+N is 20-700Hz+1300Hz-44.1kHz with 88.2kHz sample rate.
You can see from the spectrum that THD+N is mostly 3rd harmonic distortion at about -101dB, I'm guessing from the gate capacitance of the pair of JFETs which set the ground reference for the other JFETs in my circuit.
I'd be interested in seeing a measurement of your PCM1794 Sen version with the 2SK369V. Have you got any results from that yet? How does the sound compare to the other ones you have built?
Old 31st October 2013, 04:19 PM   #1580
EUVL is offline EUVL  Europe
Subjectively AD1865 sounds much better.
Stunning was the word used for the AD1865.
But the front end is different (CS8416 SPDIF for 1794 vs Ultimate Source 2 for 1865).
So it is probably not a fair comparison.
At least we know it works for AD1865, PCM1704, ES9018, PCM1794, ....
And we might try AD1955 some time, but very low priority....
Patrick
xen-audio.com
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright ©1999-2017 diyAudio
