Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 156 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th October 2013, 01:15 PM   #1551
triode_al's Avatar
Would single ended be possible? That is, k170 top/bottom and current source?
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 15th October 2013, 01:48 PM   #1552
EUVL is offline EUVL  Europe
We'll publish in due course.
Patrick
xen-audio.com
Old 16th October 2013, 09:45 AM   #1553
heb1001 is offline heb1001  China
Originally Posted by EUVL View Post
For those interested, here is our quick-&-dirty prototype of a SEN IV for PCM1794.
You got this working yet? I never got around to trying your simple bias solution. Curious to know whether it's stable enough to perform well.
Old 16th October 2013, 10:23 AM   #1554
It is stable enough. That we have tested and the results are posted.
But we have not tested it on the DAC.
The original PCB needs the analog stage stripped and replaced first.
Patrick
xen-audio.com
Old 17th October 2013, 05:45 AM   #1555
Calvin is offline Calvin  Germany
Calvin's Avatar
The simple JFET ccs not only works stable, but may easily be trimmed after due warm-up and is probabely the lowest noise ccs one could us here.
The ccs will be the dominant noise source of the complete circuit!
I tested several ccs structures and the JFET remained choice no1 and I use it for years in my iv circuits for the PCM179x.
Just make sure that its heavily degenerated to achieve a high enough impedance, as too low inpedance values affect THD.
JFETs like the 4391 are also a good choice here, if one doesnt want to rely on obsolete parts.
jauu
Calvin
Old 17th October 2013, 06:01 AM   #1556
Only the old Siliconix datasheet has a noise figure for the 4391 of 3nV/(sqrtHz).
All currently available ones (Philips, Fairchild, OnSemi) are not specified.
So 2SK369V and the like is still the better choice I think.
You can also use 2SK246BL and degenerate to 2mA or so.
Need to use 3x in parallel.
Patrick
xen-audio.com
Old 17th October 2013, 11:11 AM   #1557
Calvin's Avatar
The interesting part about the 4391 is its high idss of ~100mA.
That allows for a a large valued source resistor, making the ccs stiffer and less noisy. Paralleling devices to achieve suffuciently large dc-currents reduces Zout and increases noise again.
So I still think, that a single high Idss JFET is a prefferable choice.
jauu
Valvin
Old 17th October 2013, 12:28 PM   #1558
Isn't it that random noise reduce by sqrt of n, where n is the number of devices in parallel ?
Else why should they bother in phono preamps ?
Patrick
xen-audio.com
Old 17th October 2013, 01:59 PM   #1559
smms73 is offline smms73  Portugal
smms73's Avatar
jauu
Calvin
Hi Calvin
I also think that the 4391 is a good option. As the 2SK369V is.
But you have to take a better look to the topology, please.
I have developed this concept of floating current source exactly to eliminate the noise from the current sources in a folded cascode. As the current source is floating, any current noise that is produced in the current source will have to return to the current source.
The impact of the current source noise in this topology is close to none.
Also the output impedance of the ccs is not a problem, the circuit works with low distortion even with a resistor as current source
The PSRR of this topology is also very high.
In the first image is the PSRR of one of the circuits we have, the other image is the distortion with a 150 ohms resistor as current source .
(simulating a pcm1794 at 7,8ma p-p).
sorry for not show all the circuit, but is under development.
Sérgio Santos
Old 17th October 2013, 02:14 PM   #1560
rsavas is offline rsavas  Canada
for public use or proprietary?
Interested to learn how to sim a I/V converter!! So more for me too learn in ltspice.
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright ©1999-2017 diyAudio
