Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 150 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th August 2013, 07:13 PM   #1491
LuisMCP is offline LuisMCP  Spain
Audio fanatic
LuisMCP's Avatar
Originally Posted by EUVL View Post
Your "drift" is very likely due to leakage in your capacitors.
Patrick
I have tested today two new type of caps:
Polarized Elna Silmic
Bipolar Nitai electrolityc
Polarized cap ended with a great clipping.
Bipolar Nitai don't
I will try Nichicon Muse next days.
I have measured harmonic distortion with the Nitai's and found 2nd harmonic below 30 dB of fundamental with only 0,2Vrms of signal (18V psu)
Probably i will get some litycs of low leakage for testing
Old 18th August 2013, 03:51 PM   #1492
So to be on the save side, I would not use anything less than 220uF for signal current up to 2.8mA rms (or +/-4mA).
If you want to use higher signal current, you should increase the cap value proportionately.
Thank you reply.
Is it necessary to use 100 ohm gate resistors AD1865 case?
Old 19th August 2013, 07:37 PM   #1493
EUVL is offline EUVL  Europe
Yes, just to be safe.
No real down side.
Patrick
xen-audio.com
Old 19th August 2013, 07:44 PM   #1494
suburra is offline suburra  Italy
Patrick
If I wanted to put 2 PCM63 in parallel (piggyback), I have to change something in my CEN (Idss 8,5 mA_Riv 2K_ +/- 24V supply) ?
Marco
Old 19th August 2013, 07:57 PM   #1495
PCM63 has +/-2mA output. I would have used 1.5k R_iv in the first place.
But if you want to use two of those in parallel, you should half the value of the R_iv (750R), and double the bias (to say 16mA).
Patrick
xen-audio.com
Old 19th August 2013, 08:11 PM   #1496
Patrick,
Just as I thought...
I tried a Tx 2352 1.5 K and a Caddock 2K
With the 2K Caddock the resulting sound, for my ears, was better
Also,
I'll try Wima MKS XL 10uF and BG N 470uF instead of my current Nitai BP 220uF and will report
Thanks a lot
Marco
Old 20th August 2013, 06:32 AM   #1497
Patrick,
because it's impossible (for me) to find K170/J74 with 16 mA Idss (from Spencer max 9 mA), may i put another matched pair (8.5 mA) in parallel?
Or better try SEN with 18mA total Idss (each 2SK170 with 9 mA)?
Marco
Old 20th August 2013, 10:15 AM   #1498
Use 2 each K170/J74 in parallel to get 17mA.
Patrick
xen-audio.com
Old 21st September 2013, 10:47 AM   #1499
how could i get this working with tda1543? the psu for sen is not separate since i want a compact form factor. the ground is shared with 1543 so how to null dc on the chip's output?
Old 21st September 2013, 12:57 PM   #1500
Hi All
after long trial i finished my output stage of my Copland
It have CEN for I/V and Gherard Buffer for LPF
For Cen i choose Wima MKS 10uF for decoupling Cap and Texas Tx2352 for resistor I/V
The sound it's wonderful, grainfree and very clear, never heard CD's sound so well
So, Patrick, THANK YOU!!
[IMG]Click the image to open in full size.[/IMG]
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright 1999-2017 diyAudio
