Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 149 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th July 2013, 12:02 PM   #1481
EUVL is offline EUVL  Europe
Panasonic FC 470F 35V, 10mm dia. x 20mm Length.
Patirck
xen-audio.com
Old 31st July 2013, 07:18 AM   #1482
Patrick and suburra
why are you using 1.4K as a R_iv with PCM63
Isn't It a 1.5 K recommended with PCM63
do I need a buffer If I drive 20 K attenuator with SEN
Old 31st July 2013, 08:04 AM   #1483
suburra is offline suburra  Italy
Hi
Patrick, for PCM 63, recomended 1.4K for 2Vrms Out
I tried 1.4K/1.2K/2K
2K was better for my ears, and Caddock Mk132 better then Vishay TX2352
For sure 10K shunt attenuator needed a buffer
Maybe with 20K you can try without
Marco
Old 31st July 2013, 08:43 AM   #1484
thank you for reply
can you describe difference with / without buffer
you said that lows are not correct ?
Old 31st July 2013, 02:40 PM   #1485
Hi
Without buffer the sound was constrict, and i had sensation to loosing control and energy in the bass frequency
With buffer no more these sensations
Now the input inpedance of DCB1 it's 28k and Res I/V is 2K
Hope my poor english was clear
Marco
Inviato dal mio GT-S5300 con Tapatalk 2
Old 12th August 2013, 07:33 AM   #1486
LuisMCP is offline LuisMCP  Spain
Audio fanatic
LuisMCP's Avatar
Default Bias point drift?
I have been some kind of "bias drifting"
With a senoidal signal of 1kHz, output is clean an undistorted in the first minute.
After 1st minute, negative half-wave becomes clipped.
If signal is square, 1kHz, no clipping.
If signal is senoidal, 40 kHz, no clipping.
If turn-off some time, 1kHz senoidal is unclipped again 1st minute.
I have fed the circuit with batteries and a regulated psu too. Results are the same independently of what PSU you use.
I believe that the capacitors are responsible for some kind of drift when they get charged, but not sure.
Old 12th August 2013, 09:34 AM   #1487
ryanj is offline ryanj  Australia
Your absolutely right, i had the same problem with some other russian film caps. But then i switch to Nichicon Muse caps and had almost no detectable DC leakage. - Nothing i could detect with my basic equipment anyway.
Old 12th August 2013, 09:58 AM   #1488
Audio fanatic
LuisMCP's Avatar
mmmm... interesting.
Ouch! I have read BOM and saw *bipolar* caps.
Mine are polarized caps
Old 13th August 2013, 01:34 PM   #1489
you can use polarized caps
Old 13th August 2013, 02:15 PM   #1490
Your "drift" is very likely due to leakage in your capacitors.
Patrick
xen-audio.com
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 06:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 12:57 PM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 05:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 04:36 PM
Copyright 1999-2017 diyAudio
