| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1351 |
Although with salas shunt, it's recommended to shunt at least 70mA on top of load, and more seems better. So i would go for around 100mA with your SEN.
#1352 |
If it should need 70mA extra to drive a 35mA load, then maybe you should consider using something else, like Walt Jung's shunt.
Patrick
xen-audio.com |
#1353 |
For the moment I'm only making tests.
But I think that I'm not making an eco friendly I/V because a resistor I/V is better to save the energy of the planet. For now the problem to solve is to obtain low noise and after I'll try other shunt configurations. Thanks and I'll keep you informed. Ciao Guglielmo |
#1354 |
Then use batteries followed by a passive LC filter. ![]() Patrick
xen-audio.com |
#1355 |
and
>For now the problem to solve is to obtain low noise Then use batteries followed by a passive LC filter
#1356 | |
But the minimum current of SSLV1.1 in original design is 100mA if i'm right, but you can always change some fets to lower it. It's just as simple as performance vs power-usage/heat. |
#1357 |
Even if this is the wrong thread I'm curios towards the validity of this postulated "simple" correlation between performance vs power usage. 1) Is it true for a constant current loads? 2) What is the correlation coefficient? You get 10% or 0.001% better performance by doubling the power usage? curios minds want to know....maybe I should ask Salas
#1358 |
when using sen Is not It better to have a lower Idss jfets In lower pair - ccs
#1359 |
No.
xen-audio.com |
#1360 |
Good morning Patrick from sunny Alicante - I say, you're an early riser on Sunday
![]() jan
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
| FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball | prooptiki | Swap Meet | 1 | 22nd May 2010 05:57 PM |
| Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A | novec | Digital Line Level | 11 | 11th May 2010 11:57 AM |
| > Audio <> music <> quick <> synergy <> angst>? | rick57 | Everything Else | 0 | 4th May 2007 04:03 PM |
| >>> cheap 50,000uF 60V capacitors here >>> | Lubomir | Swap Meet | 0 | 1st February 2007 03:36 PM |
