Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 126 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th October 2012, 06:32 AM   #1251
Patrick
can I use 1 pcs of high Ah car battery 12V + another 6V battery for two se sen channels
Old 5th October 2012, 06:44 AM   #1252
MiiB is offline MiiB  Denmark
You cant mix the supply of two channels, each need a seperate floating supply.
Old 5th October 2012, 02:40 PM   #1253
EUVL is offline EUVL  Europe
Spot on, MiiB.
Patrick
xen-audio.com
Old 6th October 2012, 07:37 PM   #1254
thank you
both of you
Old 22nd October 2012, 10:07 PM   #1255
RollE2k is offline RollE2k  Sweden
If running balanced and i have one +-18v PSU, should i just run +18v to positive phase and -18v to negative phase? and then paralleled over both channels?
Also, approx how much current would in total can i expect (per phase) if running 6x SK170's in CEN config?
Is it just six times IDSS which is TOTAL current draw per phase in that config?
Old 22nd October 2012, 10:21 PM   #1256
NicMac is offline NicMac  Italy
NicMac's Avatar
Originally Posted by RollE2k View Post
If running balanced and i have one +-18v PSU.......
You need 4 supplies. Try to do your homework just a tiny bit.
Old 22nd October 2012, 10:27 PM   #1257
A +-18v supply is twin supply, which i thought would work. Too bad that you need two of them, since i have no room for that.
And sorry, if i don't have time reading through 26 pages of text.
Old 22nd October 2012, 10:30 PM   #1258
qusp is offline qusp  Australia
qusp's Avatar
26 pages? well its in the build manual, BOM and schematic on the first page too....
its also not calling for a bipolar supply....
it needs a 17-18vdc floating supply for each phase of each channel, so 4 in total
Old 4th November 2012, 06:24 PM   #1259
Red face still working on it
I have built this sen circuit using P2P. I also still have problems with getting it to operate with both channels connected. I am using PCM1702s and the original circuit design. Must be in the player as If one channel is connected, it operates fine(the other channel with a 1K on it). When I connect both, the working channel get's "jittery" and the new channel has high speed modulated signal wave and half the amplitude of the working one. Have not put in the stopper yet. Thought it would be easier but still working on it.
Old 4th November 2012, 08:03 PM   #1260
Talking More info
Here is the physical layout of my attempt at P2P construction. Each channel draws 19.4 ma according to my DVM. Anything wrong with the layout? The wiring is correct! I see no oscillation on my 10mhz scope.
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright 1999-2017 diyAudio
