Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 124 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th September 2012, 11:19 AM   #1231
needsp is offline needsp  United Kingdom
Hi Patrick
you meant you prefer a side-by-side arrangement and not DAC above SEN ??
After all, you cannot make it to buzz with side-by-side, right ?
Yes. Though I can't that all side by side implementations would be problem free, mine is at the moment. Personally given the problems I've had with stacked arrangement, and the (now) obvious (theoretical) greater susceptibility of that layout to rf problems, I'll be sticking with the side by side arrangement in future.
Paul
Old 24th September 2012, 01:07 PM   #1232
EUVL is offline EUVL  Europe
> and the (now) obvious (theoretical) greater susceptibility of the stacked layout to rf problems ....
Is it not that this has now been proven by at least one experimental set up, rather than just "prejudice" as quoted in post #1209 ?
Patrick
xen-audio.com
Old 25th September 2012, 08:20 AM   #1233
Originally Posted by Bemused View Post
OMG, thst must be a part of project on Electronic warfare ? How many watts does it emits?
No wonder opamps work bad in these conditions.
Old 25th September 2012, 08:52 AM   #1234
Nothing compared to a Class A power amp.
Why not just use DSD to drive digital-input switching power amps direct ?
Nothing can beat that by energy efficiency.
I am sure they can also sound fantastic.
Patrick
xen-audio.com
Old 25th September 2012, 09:44 AM   #1235
Bemused is offline Bemused  United Kingdom
Its just a pair of Buffalo, Arduino and eighten regulators four of which are hungry shunts as most Buffalo builds have the remainder are linier so harly any more power than a standard build, looks messy because most regulators are hard against the Buffalos with short wiring.
Old 25th September 2012, 03:34 PM   #1236
Well, maybe I used wrong term. Mayby "radiates" suites here better. But, anyway, with such layout your dac will radiate and recieve tons of RF garbage. DAC contains very high speed clock signals, with rise times orders if 5 nsec, it tends to spred upon any wire it "sees" around. Things are especially scary because you are using sabre, which has very righ output current - around 10 mA. Output current contains EM spectrum up to GHz range. Any power amp will not be happy to see it on its input .
Another problem is separate i/u and dac boards, one of the worst things you can do to delta-sigma converter because abovementioned HF modulation. The worther might be only using one output in a couple. By design, delta-sigma dac might be considered high-speed digital chip, with lots of digital logic: digital filer, ASRC in case of Sabre, DS modulator. All this logic emits RF noise, but it is common to I+ and I-. To remove it, stage for a substraction should be used.
Personally I ended few times with layout like that. Every time I tried to compare them with my Dell laptom build in sound, and it was better, especyally after some filtering. Of course, I can not extrapolate anything anywhere
Old 25th September 2012, 03:42 PM   #1237
Here you can see optimised layout for DS dac Google Translate
Old 25th September 2012, 05:10 PM   #1238
Waiting for Xcen
Old 25th September 2012, 05:38 PM   #1239
Currently undergoing Beta tests by various people.
Patrick
xen-audio.com
Old 25th September 2012, 07:07 PM   #1240
Patrick
Thanks, have been watching your activity
Looking forward to the release
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright 1999-2017 diyAudio
