Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 118 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th September 2012, 06:31 PM   #1171
EUVL is offline EUVL  Europe
How many PCM1702s do you have in your DAC, and do you have a schematics of the analog output stage after the 1702 ?
Without the schematics it is rather difficult to help, unless you only have 2x PCM1702 inside.
Best is to find a fellow DIYer nearby and skill enough to understand and willing to help.
Patrick
xen-audio.com
Old 8th September 2012, 02:39 AM   #1172
Talking Thanks for the clarification
I will build this sen/cen for an Adcom cd player which has only one PCM1702 per channel. The player has a class A opamp IV and filtering system with relays muting. Just needed a little clarification. Thanks again.
Old 8th September 2012, 03:37 AM   #1173
bcarso is offline bcarso  United States
I suspected as much (the single 1702). Thanks!
Old 8th September 2012, 04:39 AM   #1174
For ONE PCM1702 per channel, you need one SEN or CEN PCB on which there are TWO single ended IV circuits.
That also means TWO floating supplies 2 channels.
A standard evaluation kit will have 2 SEN and 2 CEN PCBs.
That gives you plenty to experiment with different devices and components, etc.
Patrick
xen-audio.com
Old 10th September 2012, 07:14 PM   #1175
Red face trying for simplicity
I have been thinking about the overall scheme of this simple and reported excellent sounding IV circuit. I like simple, and minamalistic systems that make the sound to my taste(acoustic, light Jass, Blues). I have a simple system, that is a cd player into mono block tube amps, into monitors in a 12x17x8 room that has had some acoustic modifications. One capacitor in the signal path, even one on/off switch. The interconnect cables are 18 inches long and the speaker lines are 36 inches in length. Minimalistic as I can make it. Additionally, I have done all the mods, PS, resistors, caps, diodes, cables, etc. on a very tight DIY budget. I have even used pulled components from the Skip/dumpster and surplus equipment to experimetnt with. That has been quite an eye opener, as there is a substantial amount of nice component being thrown away.
What I am thinking about here is the PS that is although simple sounding, requires(recommended) 32 AA batteries at a cost of 3 euro each. It would also appear that a charging circuit would be recommended, incorperated into the on/off button. This requires a lot of shall we say real estate, and expense for only the IV segment of our systems. I realise that a 9v battery system(requires 4each) would get a person at least to the evaluation phase and possibly longer term. That will be my solution in keeping this as simple as possible. Thank you for this opportunity!
What I am finding is that although there are many excellent projects here on DIY Audio, the ones I seem interested in building have a "snag" somewhere. Be it hard to get or very expensive components, or additional spacific requirements not at first addressed in the early discussion. That is why I must wait until the thread has reached maturity, so I may fill in all the holes before moving forward.
Mind you, I wouldn't be without my membership here. I really appreciate the thought and efforts all the memebers put into this website. Without this, I would still be using the old RCA console my parents had.......
Old 13th September 2012, 07:22 AM   #1176
Originally Posted by EUVL View Post
L = 10mH Fastron 77A series
DCR = 12R
dV ~ 0.5V @ 45mA
C = 10000uF 16V Vishay BC 056 Series
f_RC = 1.3Hz (1st order)
f_LC = 16 Hz (2nd order)
Patrick
Would it be ok if I change the C to 15,000uf ? Reason being I have them in stock instead of 10,000uf
Old 13th September 2012, 08:35 AM   #1177
Of course. Just try it and listen.
BTW the 16V was a mistake of mine.
You should use 25V or whatever voltage that is higher than your rails.
Patrick
xen-audio.com
Old 13th September 2012, 01:25 PM   #1178
Patrick
Great !!! I'll take a note on voltage rating of the capacitor.
Thanks.
Old 15th September 2012, 09:52 AM   #1179
One question on the battery-supply:
Instead of using
- 4* 18v with many AAA for two v18 (used as balanced output to drive a balanced input stage of a tube amp) would it not as well possible to use
- 2 19.9V A123 based supplies (channel separation is already there than, but not for each phase...is this really a disadvantage ? If you use a balanced signal path you want to introduced in the two phases the same noise so it can cancel itself out....)
- Is 19.9V fine ? The A123 has 2300mA and very low ESR...and compact...
Additional question:
The V18 will drive a 6922-input stage in a UL40 of menno VanderVeen ( a EL34-PP). I will modify the input stage so it is balanced and get rid of the phase splitter and have a fully balanced system. The 6922 is cathode biased, so in theory I can give it an inout resistance upto 1 MegOHm...today it has 100kohm.
What would be the sufficient coupling cap than ? I ommitted all electrolytics out of my system an do not want to put any in now again...(currently I am using the unbalancer from broskie with Mundorf tubecaps).
Old 15th September 2012, 04:11 PM   #1180
Default Experience with SEN in ES9018 /Buffalo DAC
Hi all,
After a long designing phase (due to lack of time) of my homebrew PCB of a stackable SEN/CEN board for the buffalo DAC, I am at last able to comment on this (fantastic by most aspects) I/V converter!
First, for curiosity: the homebrew PCB which has room for 3 pairs by channel (my logic was that three 2SK170BL pairs would give same transconductance and Idss as two 2SK369V pairs, but a slightly lower total input capacitance) :
I made it for personnal use, so no need to ask for a group buy... (see EUVL comment earlier in the thread..... if you need advices to design your own, you may contact me though...)
Then the stuffed proto board.
I am using a 1% matched 2SK170 hexadeca-tet (16 JFETs) for now.. I will increase to 3 pairs by channel later, ......I know the wires are flying but that's for a first try...
I did not use the famous heatsinks and got the output stable at less than 2mV.. I might see later if the expense of these heatsinks is worth..
Finally The full assembly:
...in my very tight (but sufficient !) casing..
As you can see it stacks directly under the Buffalo DAC, making a nice stockpile of boards with all these regulators above !
On the sound:
It is very good! As NicMac said, probably the best single upgrade in my system. I am being very subjective of course and I will not go as far as using superlatives, but the realism and details increased noticeably (I do not have the patience / experience / ears and equipment to do ABX tests, but bottomline I like the result a lot). Very happy about the build.
Drawbacks of my build: I do not have a balanced system, and I did not use a Bal-> SE conversion (yet)... just took one phase from the SEN. When having my ears close (but even not so close) to my 95dB speakers, I can hear a buzz similar to a ground loop which I did not have previously with the Legato IV.... with floating batteries I really don't see how I could have possibly created a ground loop, but .... even with this, I can still hear an improvement in the sound of my system... just leaving me wonder how great it could be if I can solve the buzz! (and where the buzz is coming from...? I will check the Buffalo Power supply layout later....)
I then tested the system in balanced mode by feeding my F2J directly from the SEN in Balanced (mono) mode. It is DEAD SILENT when idle (finally I can understand what that means!) and plays really good music.. even though I can not appreciate the stereo and depth of the music, but definitely, leaves me wanting to either solve the buzz, either use a Bal/SE, or build another amp to appreciate the balanced sound.
For now I'll just listen to the Beatles Mono recordings collection.....
Fred
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 06:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 12:57 PM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 05:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 04:36 PM
Copyright 1999-2017 diyAudio
