Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sony NS 900C wont read all SACD discs
Old 22nd August 2011, 01:40 PM   #1
microx is offline microx  Spain
Default Sony NS 900C wont read all SACD discs
Hi all, just bought a a second hand Sony NS 900v universal DVD player. Some sacd's play every time, others sometimes and some never. All other formats play fine. Any ideas? microx
Old 24th August 2011, 02:35 AM   #2
stephensank is offline stephensank  United States
The whole generation of Sony dvd players in that NS range have terribly unreliable lasers and mechanisms. Although it is remotely possible you might cure the fault by finding a service manual and going through the self-calibration procedure in the service menu, it is more likely that the laser is simply dying.
Old 24th August 2011, 11:34 AM   #3
Hi, thanks for your reply. I have the service manual but from memory the remote I have is missing one button needed to open the diagnosis/calibration files. Do you think it likely that replacing the laser will CURE the problem or is the machine just not very good at reading hybrid layers?
Old 25th August 2011, 03:04 AM   #4
It's fairly likely that replacing the laser, or, better, the whole laser/tracking drive/platter drive "traverse mech", will cure the problem without further work required, but I have not worked on enough of these to say that with a high degree of confidence.
Old 25th August 2011, 09:30 AM   #5
Yes, I think it's a fair bet so I have ordered a complete platter. Do you think it will need calibration? if so I will have to solve the problem with the missing button on the remote, the manual says_
The Test Mode allows you to make diagnosis and adjustment easily
using the remote commander and monitor TV. The instructions,
diagnostic results, etc. are given on the on-screen display (OSD).
Note: Since the remote commander belongs to this model has no
number buttons, use other DVD remote commander with
number buttons on it.
6-2. STARTING TEST MODE
Press the [TITLE], [CLEAR], [POWER] keys on the remote commander
in this order with the power of main unit in OFF status,
and the Test Mode starts, then “DIAG START” will be displayed
on the fluorescent display tube and the menu shown below will be
displayed on the TV screen. At the bottom of menu screen, the
model name and revision number are displayed. Last Off at the
lower right of screen indicates the information code concerning
the last power off.
To execute each function, select the desired menu and press its
number on the remote commander.
To exit from the Test Mode, press the [POWER] key.
the remote I have is the original and it does have a numeric pad but does not have a "TITLE" button which I need to enter test mode.microx
Old 26th August 2011, 05:04 AM   #6
There's a reasonable chance it will work just fine without self-calibration, but, if not, you'll need to buy or borrow another remote. Any Sony dvd remote with the right buttons will work.
Old 26th August 2011, 07:50 AM   #7
Many thanks for your input, I will let you know how it goes. microx
Sony NS 900C wont read all SACD discsHide this!Advertise here!
Denon DVD-2200 Player Wont Read CDs silvercans Digital Source 0 16th December 2009 03:40 AM
Denon DVD-5900 can't read SACD, any mods available? Gadget King Digital Source 1 24th August 2009 03:33 AM
Sony Reference Discs EUVL Digital Source 0 18th May 2007 01:31 PM
Musical Fidelity DVD1 wont read any discs andjur78 Digital Source 0 9th August 2005 09:02 PM
Copyright ©1999-2017 diyAudio
