Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Lowering source voltage
Old 19th August 2011, 10:16 PM   #1
jtavrisov is offline jtavrisov
Default Lowering source voltage
Is there a good way to reduce the source voltage. I have a chip in my design that only allows an input of +/- 2.5V, however I just plugged in my source and the sound clips badly meaning I exceeded those limits. Using my phone as a source yields the exact same result when the volume is at max, reducing it returns the sound to perfection.
However unlike my phone the source I intend to use has no volume control so how can I attenuate it. Would it be as simple as putting a resistor in series?
Old 19th August 2011, 10:18 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
You can turn the volume down on the source.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 19th August 2011, 10:21 PM   #3
As stated above, that is not an option. There are no volume controls
Old 19th August 2011, 10:23 PM   #4
Everything i own, phones mp3 players etc etc all have software volume controls on them.
Old 19th August 2011, 10:30 PM   #5
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Two resistors in a voltage divider. If you don't know what voltage levels are involved you'll have to find the best resistor ratio values. Or you could install a potentiometer.
OT commentary: With digital sources, I tend to question whether these hot sources are really worth it, or just trendy audiophile fashion.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 19th August 2011, 11:28 PM   #6
Well I'm stuck with the source, in fact the whole project is because of this source.
As far as the voltage divider, the ratio is one thing but should I go for higher value resistors or lower values? The extent of my circuit analysis goes to DC analysis and just textbook examples.
Old 19th August 2011, 11:44 PM   #7
sofaspud's Avatar
Lower values are generally better, but both the output and input will see the impedance, and you have to keep them happy. Myself, I'd probably try a 1k resistor to ground, find a suitable series resistor, and give it a good listening test. Replace with a 4.7k to ground if need be. I don't know your source; maybe its circuit gain could be reduced to suit your app.
Old 19th August 2011, 11:48 PM   #8
Okay thanks, I probably try to use the same two resistors to get a 1/2 voltage divider. Keeps it simple especially since its going to be amped afterward.
Old 19th August 2011, 11:55 PM   #9
sofaspud's Avatar
That will work. I'm not opposed to hot sources, but it's important to keep them in the context of overall gain structure. As you've experienced.
Lowering source voltageHide this!Advertise here!
Lowering B+ voltage blue lander Tubelab 41 31st May 2013 07:20 PM
PC for a source. Help lowering PS noise. HaLo6 Digital Line Level 22 12th February 2009 02:58 AM
Lowering voltage output of transformer TGRANT Tubes / Valves 8 17th January 2007 10:29 AM
lowering the voltage Lowjacker Power Supplies 7 11th March 2006 09:11 AM
Help with lowering filament winding voltage. G Tubes / Valves 7 8th September 2003 11:36 PM
