| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have an older Denon DCD 425 that has dim front panel display. I'd like to fix it so that I can see it during the day. I haven't torn the unit apart yet, but if the repairs are as easy as replacing the lamps on a Carver M-500, I'm in. Does anyone know what pats are needed, or how difficult it might be?
#2 |
SVA-7MM03 (FL851).
#3 |
Thank you. Now, to find a source...
#4 |
That might be problematic. Attached is the pinout in case that you want to check some voltages (filament voltage goes thru the switch SW501 contacts)... Also I had once in one player the capacitor for high-voltage dry-out.
#5 |
Thanks for the schematic view. Fixing looks like more of a pain than it's worth. Since it works, and is only dimmer, I guess I'll live with it.
#6 |
Sometimes it happens that the display has dust (cigarette smoke) deposited on its surface...
#7 |
I'll check it out. It also may be partially unseated from it's mounting.
| Denon 4308A vs Denon 4308CI-an idiot's oddisey | aghory | Solid State | 0 | 5th February 2011 01:38 AM |
| Any Denon techs out there? Denon POA-4400 with no power | SPL db | Solid State | 0 | 2nd November 2010 02:02 PM |
| Electronic Lamps, electricity, i need help, lamps burning, needing procedure | destroyer X | Solid State | 27 | 13th September 2005 09:27 AM |
| projector lamps | mytts69 | Everything Else | 1 | 17th July 2003 12:03 PM |
| Page generated in 0.07866 seconds (76.25% PHP - 23.75% MySQL) with 11 queries |
