Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd August 2011, 05:49 PM   #1
Default CD 6002 help
I have been told that it will cost £145 to replace the laser drive unit, which upsets me as this product is only three years old and as an OAP not used all that much.
Can anyone tell me if I buy the KSM213ccm how difficult for a novice is it to take the old one out and refit the new one?
Do I need a professional or can I diy?
mike
Old 3rd August 2011, 05:38 AM   #2
You can change the assembly yourself , but there are several points you should be aware of:
*Laser diodes are static sensitive, that means you could break them by touching them
*many new lasers have two pins shorted on the pickup pcb to prevent damage in transit (this solder bridge must be removed before use)
*the laser is very sensitive to power variations, too much power and it will break, but apparently the control is set at the factory.
*many cd players have adjustments that require measurement tools (but not your cdp) .
Also, if you do attempt to change the mechanism, you should probably be aware that most of the laser light is actually invisible, and it can damage your eyes even if to you it looks less bright than an led. So don't look into it when it's on.
Mods to Marantz CD-6002 arupg Digital Source 14 2nd August 2011 04:35 PM
marantz cd 6002 bbgood Digital Source 1 27th April 2011 10:58 PM
AKAI CD 93 or CD 73 cd players are sought tuncay Swap Meet 1 11th December 2006 07:01 PM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 08:29 AM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
Page generated in 0.07131 seconds (73.06% PHP - 26.94% MySQL) with 10 queries
