Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Annoying "No Disc" Error Please Help!
Old 16th July 2011, 04:07 PM   #1
form109 is offline form109  United States
Default Annoying "No Disc" Error Please Help!
I Have a Sony Stereo...every now and then i get a "No Disc" Error from it....but in the last few weeks every single Disc i put into it returns a "No Disc" Error,and the Disc's i put in are known good Discs that are clean and scratch free,i even disassembled the unit to clean the lense...which wasn't even dirty...any ideas guys?
Old 16th July 2011, 04:11 PM   #2
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
How old is it? It could be mechanical wear of the platten bearings or possibly old/failing electrolytic capacitors causing problems.
Mike
Old 16th July 2011, 04:56 PM   #3
Mike
The System is a little over a year old...with VERY minimal use of the CD Player.
Old 16th July 2011, 05:40 PM   #4
Mooly's Avatar
What's the model number out of interest ?
Do you know the pickup type number ? Usually KSSxxx although at only a year old...
Does the lens perform a "focus search" routine immediately after the drawer is closed. The lens should move up and down approx 3 times.
Old 16th July 2011, 05:44 PM   #5
That's unfortunate, any chance the manufactuers' warranty is still good? If not it might be worth trying to contact the place you purchased it and see if they will work with you, I'd try that before attempting to fix it on your own.
Mike
Old 16th July 2011, 05:48 PM   #6
I should have added that a failure in a device that new and unused is most likely a manufacturing defect, so it wouldn't be unreasonable to expect the seller or manufacturer to try to make it right.
Mike
Old 18th July 2011, 11:58 AM   #7
The Model Number if the Stereo is the Now Discontinued MHC-EC98Pi.
an even bigger issue now is there's no output from the amps as some relay clicks closed immediately when the unit is powered on.
Annoying "No Disc" Error Please Help!Hide this!Advertise here!
NAD C525BEE - "No Disc" Trouble Shooting Advice wanted tiefbassuebertr Digital Source 20 30th May 2011 07:37 PM
Marantz CD6002 "No Disc" Error dnice1 Digital Source 4 19th June 2010 02:18 PM
We can do something to avoid the "annoying contestator" destroyer X Everything Else 7 14th October 2005 12:47 PM
