diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   ESS ES9023 DAC (http://www.diyaudio.com/forums/digital-source/192510-ess-es9023-dac.html)
rvrazvan 13th July 2011 01:00 AM
ESS ES9023 DAC
Is anyone around here using this DAC chip?
I'm buying a few this week and i will need some help with the implementation.
buzzforb 13th July 2011 01:20 AM
Check out the thread on ess 9022
abraxalito 13th July 2011 01:21 AM
Implementation is very straight forward, that's one of the key benefits of this chip. That and low power with single supply voltage.
alexlee188 13th July 2011 01:53 AM
See the latest post in the "open source USB-DAC - audio widget" thread. There is a PDF of the AB-1.1 schematic with the es0023.
Alex
samoloko 13th July 2011 07:08 AM
Originally Posted by rvrazvan (http://www.diyaudio.com/forums/digital-source/192510-ess-es9023-dac-post2637255.html#post2637255)
what sort of Implementation
I see that people mainly use It as a I2S Input DAC
I am also Interested but I need and spdif receiver part
can you buy few es9023 for me
rvrazvan 13th July 2011 07:53 AM
Originally Posted by samoloko (http://www.diyaudio.com/forums/digital-source/192510-ess-es9023-dac-post2637460.html#post2637460)
Talk with the user massimo. He might have some more chips left. I'm buying from him.
I will also need a spdif/toslink reciver. And it will be the first dac ever for me.
:confused::confused::confused::confused:
rvrazvan 13th July 2011 08:05 AM
Originally Posted by alexlee188 (http://www.diyaudio.com/forums/digital-source/192510-ess-es9023-dac-post2637290.html#post2637290)
Alex
thanks!
Is there also a pcb file there? i haven't found it :-(
alexlee188 13th July 2011 08:51 AM
The schematic is open source. The pcb layout is proprietary.
Alex
massimo 13th July 2011 10:24 AM
Originally Posted by rvrazvan (http://www.diyaudio.com/forums/digital-source/192510-ess-es9023-dac-post2637486.html#post2637486)
10 pcs still available......
massimo 13th July 2011 10:26 AM
WM8804 is good & cheap (around 3 EUR)
Resources saved on this page: MySQL 18.75%
