Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Need help with Analogmetric TDA1541 DAC
Old 9th October 2012, 01:56 AM   #121
Torchwood421 is offline Torchwood421  United States
Hi ekidnah09, Is there a value on the Murata ferrite bead? I may have some ferrite beads in my electronics stash. The parts you mention (r17 and c34) are where the digital and analog grounds come together. That could make a difference.... I don't use the analog stage. However improved decoupling is always an improvement. Thanks for the suggestions. I have built 2 of these with some experimental mods. Interesting how the 2 don't sound at all the same. Dave
Old 11th October 2012, 01:36 AM   #122
ekidnah09 is offline ekidnah09  Australia
Default Ferrite bead details
Hi Torchwood421,
I used manufactures no BL02RN1R2M2B these have a 50ohm impedance between 20Mhz and 1000Mhz.
There are two others in the Farnel E14 catalogue BL01RN1A1D28 same specifications but axial construction or the BL02RN2R1M2B which is radial with 2 beads lowering the range to 4Mhz.
Farnel numbers are 9526838, 9526820 and 9526846.
I have no real reason for using the ones I used.
On many other DAC data sheets they show the digital and analog ground plains linked via a ferrite bead so I thought I would give it a go and to me in my system the sound improved a touch (more clearer).
It's a cheap mod and if you don't like it easy to undo.
I'm working on more mods to the analog stage, as I'm a learner I will stick with op amps for a while. The decoupling improved things and I'm presently reading as much as I can about op amps and how to optimise the cctry around them.
I have also got to read up on tda1541 decoulpling that's a whole thread of it's own.
Happy listening.
regards
Giovanni
Old 11th October 2012, 02:26 AM   #123
dacen is offline dacen  Norway
Nakamichi DAC101
Just want to direct your attention to this DAC if you are into TDA1541. This unit is made for car entertainment, but it contains two TDA1541A S1 Single Crown in what seems to be differential mode. I got hold of one from Ebay. They show up from time to time. Am in the process of disconnecting the built in switch mode power supply (12v to +- 15 and 5v) and change to an analog supply.
This is a very nice unit to do some tweaking on. BTW I paid $100 for mine.
Need help with Analogmetric TDA1541 DACHide this!Advertise here!
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 08:03 AM
which clock for analogmetric tda1541A dac kit Chilli6565 Digital Source 4 6th May 2010 01:41 PM
It's my TDA1541 dac purer Digital Source 11 25th July 2006 08:19 AM
