Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Another TDA1541A based dac (dual differential)
Old 22nd December 2012, 04:26 PM   #61
Tazzz is offline Tazzz
I changed the HEF4517 for a CPLD (XC9572XL) to split the i2s into left and right now 96K is not a problem but for 192k the frames need to be 32f or data input in the simultaneous format, I have seen some reports of the latter being superior but I need to figure out how to best invert the msb in a serial data stream before I'll attempt it.
I have also tested an amanero async usb to i2s module in the converter with Jtest (using arta to generate the testfile) and attached here are the measurements,
I also tried the amanero with an improved low noise regulator (simple LTC6655 + pass transistor)
Old 23rd December 2012, 09:20 AM   #62
Here are a pair of extra measurements, apears as the noisefloor I see is what I get when the amanero is actively recieving a data stream.
File Type: png noisefloor usb connected_but signal is off.png (63.4 KB, 78 views)
Old 23rd December 2012, 09:51 AM   #63
regal is offline regal  United States
What soundcard are you using? Those are impressive measurements!
Old 23rd December 2012, 09:59 AM   #64
They were taken with a juli@.
Old 11th May 2013, 09:46 AM   #65
I did some mods to the amanero module I improved the decoupling by adding some 10uf/0603/6.3V in parallel with the original 100nF caps this extends the flatness of the decoupling impedance without to much effort. (see attached LT simulation based on models from muratas simsurfing web resource) notice the scales !
I also did a couple of slight trace cut jobs to separate the 3.3V plane between the atmel and the xilinx cpld. Im feeding the usb inteface backwards through the 3.3V ports by TL431 based shunt regulators as Im using it as a replacement for a CS8412.
Also I found why the noisefloor was degraded when fed through the amanero I had to export the Jtest signal as a .wav file from arta and play it back through foobar with wasapi plug in.
Then the noisefloor drops see attached image for jtest result.
Another TDA1541A based dac (dual differential)Hide this!Advertise here!
Discrete Dual Differential DAC? dantwomey Digital Source 18 5th March 2011 06:24 AM
Differential TDA1543 based NOS DAC dsavitsk Digital Line Level 0 6th April 2009 06:41 PM
Only noise from TDA1541A based Sphinx Project 3 DAC Lucas Unger Digital Source 10 10th June 2006 12:53 PM
Wanted: Dac pcb for tda1541a (non tube based) ash_dac Swap Meet 6 7th January 2006 05:44 PM
DAC in Dual Differential mode - schematic? spavleski Digital Source 13 25th September 2005 04:09 PM
Copyright ©1999-2017 diyAudio
