Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Another TDA1541A based dac (dual differential)
Old 7th July 2011, 05:12 PM   #11
studiostevus is offline studiostevus  Netherlands
For what reason?
In general, it is highly debateable whether there is an advantage in a differential setup anyway.
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 7th July 2011, 05:33 PM   #12
batteryman is offline batteryman  United Kingdom
Originally Posted by Tazzz View Post
You don't get all the benefits from running differential if you do it that way you really should split up the I2S into left and right and use separate dacs for the different channels.
Yes, I was thinking that way might be worth trying. I might try both ways and see if I can hear the difference although I can't quite see why splitting them as you suggest gives a benefit.
Perhaps you could explain in more detail.
Old 7th July 2011, 08:38 PM   #13
Tazzz is offline Tazzz
Doing it with one dac for each channel simplifies layout issues pertaining to making the signals equal and opposite and it allows one to resolve current loops locally and/or make opposite currents sum to zero which also helps minimizing unwanted potential differences from currents flowing where they should not.
Also if you look at a -60db 1Khz spectra of a 1541 you will notice that one channel usually measures worse and that this is usually tied to the same channel even between different dacs. Running one dac with inverted data would compound this error.
And there is also that that any time difference between when the different dacs latch out a new sample would translate into a level error at the output.
Old 7th July 2011, 08:47 PM   #14
Agree.
But why use two dacs in the first place?
Old 7th July 2011, 09:45 PM   #15
It cancels out even order harmonics the 1541a benefits greatly from this. With a differential implementation the -60db 1Khz spectra really looks very very good, even compared to the previous 1541a based dac I had which was not bad.
Listening with a good 1541a and the gain turned up that -60db signal still sounds like pure sine.
Old 7th July 2011, 09:52 PM   #16
Mmmmm... Interesting. Can you attach a picture of the fft you refer to?
Old 8th July 2011, 07:47 AM   #17
Thanks, that make sense so will do it that way.
I
Old 8th July 2011, 08:34 AM   #18
You could also argue that the added logic would introduce jitter which may have a more detrimental effect than the benefits of such a setup....
I considering a balanced setup myself, but yet need to be convinced of its merits
Old 8th July 2011, 08:55 AM   #19
The Audio Note Dacs* split the data into L & R for the AD1865 dac which doesn't have I2S input, using a 74xx02 and they aren't known for having jitter problems.
(*nos design - Cs8414 input )
In my case, the Sowter I/V transformer is designed for differential input so there is not really any extra complexity other than a 74hct02 and the 2nd 1541.
Old 8th July 2011, 01:34 PM   #20
A simplistic view would be (using a 1541 per channel as Tazzz recommends) and considering one channel:
Inputs: L & -L (-L = L data inverted)
Ouputs L + noise and -L + noise.
Subtract in a bifilar wound I/V transformer (swap start and end of one winding to achieve this) results in:
L- -L = 2L and because the noise was added within the dac,
noise - noise = no noise (well, less noise!)
On a separate subject:
What are the consequences of inserting an LC filter with an f-3 of about 15-16kHz* between the 1541 outputs and I/V transformer?
As the impedance needs to kept very low, use of an inductor should be practicable. (Sowter suggest a 200R load resistor on the dac output)
*my ancient ears probably don't work above 12-15KHz!
I
Another TDA1541A based dac (dual differential)Hide this!Advertise here!
Discrete Dual Differential DAC? dantwomey Digital Source 18 5th March 2011 06:24 AM
Differential TDA1543 based NOS DAC dsavitsk Digital Line Level 0 6th April 2009 06:41 PM
Only noise from TDA1541A based Sphinx Project 3 DAC Lucas Unger Digital Source 10 10th June 2006 12:53 PM
Wanted: Dac pcb for tda1541a (non tube based) ash_dac Swap Meet 6 7th January 2006 05:44 PM
DAC in Dual Differential mode - schematic? spavleski Digital Source 13 25th September 2005 04:09 PM
