Micromega Solo CD Player - help!! - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th July 2011, 07:29 PM   #21
Mooly's Avatar
Thanks for the pic. I don't think for a moment the transformer is suspect.
Now I don't know how easy this thing is for you to work on and take measurements but, in the absence of any circuit diagrams it makes sense not to overlook anything. Remember though that these are basic tests only so don't get your hopes up too much.
OK we have to start somewhere. Please be careful measuring voltages... no danger, but a slip with the meter probes could cause damage. All the readings are taken with the black lead of the meter on chassis ground or "zero" volts point which can be the outer ground part of the RCA audio sockets. Some of these measurements may seem a bit random and even non related parts of the circuit but I'm working off the pics which is easier to describe from and trying to cover all supply possibilities.
Pin markings on "normal" IC's begin with pin 1 at the spot or mark in the corner and work round the IC. So in the first one here pin 1 and 14 are opposite each other.
Looking at your picture in post #10 measure the voltage on pin 14 of the IC marked MC74HCD04N. It should be 5 volts.
To the left of that IC is a smaller one marked LF356N. Measure the voltages on pins 4 and 7. They should be equal and opposite. For example +9 volts on pin 7 and -9 volts on pin 4. The actual voltage could be anywhere from 5 to 18 volts depending on the design.
Thats a first step...
I'll post a bit more in a minute.
Installing and using LTspice IV. From beginner to advanced.
Old 6th July 2011, 07:34 PM   #22
Mooly's Avatar
And these 6 measurements here A to F
Old 6th July 2011, 07:41 PM   #23
Mooly's Avatar
And on the TDA5709 (on the other board) the voltage on pins 6, 11 and 17.
What is on each ?
Also pins 4 and 8 of that little 8 legged IC the 4560. What is on those too.
It will probably be Friday before I can look in again in detail...
Old 6th July 2011, 08:04 PM   #24
Thanks very much - when I can get some good daylight I will record the voltages!
David
Old 6th July 2011, 08:08 PM   #25
Mooly's Avatar
OK... take it slow and write everything down. What we are looking for is any obvious error, missing supply or a very low supply etc.
Checking supplies is the first rule of faultfinding really... but as I say don't get your hopes up too much.
Old 6th July 2011, 09:52 PM   #26
guido is offline guido  Netherlands
guido's Avatar
Try to find somebody in your neighbourhood (on this forum or similar) who is familiar with philips/marantz players. Would be easy for such a person to find the problem.
Checking the supplies is a good start and do-able, but after that you will soon need a scope to poke around.
I'm too far away myself
GuidoB
Old 6th July 2011, 10:43 PM   #27
What is on each ?
Measured the following:
MC7HCD04N Pin 14 4.69V
L356N Pin 4 15.09V
Pin 7 -14.93V
On Main Board
A -4.75V
B 0.00V
C -4.98V
D -4.97V
E -4.79V
F 0.00V
Also
TDA 5709
Pin 6 -4.58V
Pin 11 4.84V
Pin 12 -0.08V
4560
Pin 4 -13.87V
Pin 8 -9.7V
Some were a little tricky to measure but I would think are pretty accurate
David
Old 7th July 2011, 07:26 AM   #28
Mooly's Avatar
They all sound good although the last one is a little unexpected and worth investigating... but again, don't get your hopes up, it may be normal.
The 4560 is a dual opamp and I suspect used for motor control. I would have expected pin 8 to be a positive reading. That said -9 on pin 8 and -15 on pin 4 is still a "valid" supply depending on the exact circuit application but it stands out a mile as not "normal".
I would recheck that reading and try and trace back pin 8 and see where it goes...
If anyone else is reading this do they know what other Philips models that "front end" board is used in ? It looks a standard Philips creation.
Those solid core wires used by Philips (they look like those anyway) can be fragile and fracture if they are bent around a lot so beware.
It will tomorrow before I can look again
Old 7th July 2011, 10:51 AM   #29
My apologies but pin 4 on the 4560 measured at +13.87V and not -13.67V - I transcribed it to my pc incorrectly
I re-checked pin 8 and it is reading -9.7V
I have also attached a close up pic of the rear of the board - with the 8 pins of the 4560 top left on the rear view of the board - pin 8 is nearest the edge fourth from the right!
I attach also a pic of components in close proximity to the 4560
Once again thanks for your help
David
Old 8th July 2011, 12:13 PM   #30
Mooly's Avatar
Hi David...
It seems the supplies as far as we can tell are OK. Without seeing a circuit diagram now I think realistically that's about as far as you can take it with only a multimeter for testing.
The CD spinning backwards could be a motor/drive/amplifier problem but without at least the correct circuit to give you very specific tests to perform, I fear it's beyond the scope of a thread such as this.
Schematic for this beautiful Micromega Solo, Trio and CD f1 (first edition) wanted tiefbassuebertr Digital Source 18 29th November 2015 03:26 PM
Micromega (LEEDH) CDF-2 CD player Sleurp Digital Source 2 21st January 2008 01:51 PM
CD Player Micromega CDF1 PRO hawktoc Digital Source 9 8th November 2005 09:35 PM
Micromega Stage 3 CD Player SPWONG Digital Source 2 7th December 2004 08:40 PM
Micromega Stage 3 CD Player SPWONG Parts 0 19th November 2003 07:37 AM
Copyright 1999-2017 diyAudio
