diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   CD63 mk2 KI - RCA Analog output Connector FIX (http://www.diyaudio.com/forums/digital-source/191420-cd63-mk2-ki-rca-analog-output-connector-fix.html)
alicenir 23rd June 2011 08:39 PM
Hi All,
i am new at this forum and would like to ask a question.
i have got a week ago i bought second hand the CD from marantz type CD63 mk2 KI(Not Modded yet :)), it is playing very well, the CDM12.1(i think) was replaced with a new one. the only thing is, when i connect my VDH cables to the CD Analog RCA connector the sound/signal is disconnecting and no sound heard. if i play with the interconnect rca connector then i can get it to work, i already replaced cable to verify it is not my VDH interconnect.
how can i fix it, can it be only loss contact on the PCB or i need to replace the RCA connectors, and if yes where do i buy them online....
I Appreciate your response.
Best regards
Nir
Fidelity Audio 23rd June 2011 09:14 PM
Dry joints on the connector mate. Common fault and easy to fix
Brent
alicenir 24th June 2011 04:25 AM
Thank you for your reply....
Do I need to take out the PCB to fix it, or I can do it directly by just opening the cover and fix the dry joints?
Nir
Mooly 24th June 2011 06:54 AM
Remove the PCB and resolder the connectors.
alicenir 25th June 2011 08:50 PM
10x!
Fidelity Audio 26th June 2011 03:39 PM
What Mooly said ;-)
Brent
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
