| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
The LM4562NA is the same as the LME49720NA
![]() The LME49720HA is the metal case version and offers better dynamics, treble and bass detail. Odd as they share the same data sheet! Brent |
#22 |
Wow, I'm obviously totally out of the op-amp loop! As soon as I read that it all came back to me from all those years ago
![]() I need to get back to my CD-63SE someday, last thing that happened was the building of some LM317/LM337 based regulator circuits to replace some of the stock 7805/7905 (?) and the next thing you know the CD player started to sound hissy as hell... I really should just put the 78xx/79xx regs back in!
"If only we'd known that iPods would unite to enslave the people they entertained." |
#23 |
I have CD-63 to be upgraded. I'm not sure what low noise regulators to use. Could you reccomend me some pieces?
#24 |
Hi Brent, would you mind confirming the correct connections for the display transformer secondaries? This is what I have, but it doesn't work.
+---- 12v -> 16.4ohm -> u267 | | +---- 0v -> u309 +---- 12v -> u311 | | +---- 0v -> u312 If this is correct then it may just be a broken trace somewhere. That section of the PCB is getting pretty flakey. Thanks, Ben
Marantz CD63KI -> PM66KI -> B&W 805S |
#25 |
Hi Ben
You have got that wrong ![]() Right lets see.... The 1st 12V winding with the resistor connects to U311 and U312. This is for the display heaters. After the resistor you should have approx 3.6V dc. If this dc is a little high you may have to raise the res value to drop it a little. There is a bit of leeway with this voltage . I also use a high watt resistor as it can get warm. The second 12V winding connects U305 (or U267) and U309 (gnd) Brent |
#26 |
Thanks a million, Brent. I'll try to rectify this tomorrow. Hopefully I didn't fry anything... :-/
| Just bought a Marantz CD63 | DRE I AM | Digital Source | 5 | 17th December 2010 08:24 PM |
| Marantz CD63 and Headphones | Megamicron | Digital Source | 5 | 25th January 2009 12:02 AM |
| Marantz CD63 | palucca | Digital Source | 3 | 27th September 2008 11:10 PM |
| Marantz CD63 Repair | big jim | Digital Source | 0 | 24th September 2007 05:45 PM |
| Marantz CD63 TWEAKing | ManUtd | Digital Source | 2 | 28th September 2003 10:47 AM |
| Page generated in 0.07041 seconds (84.67% PHP - 15.33% MySQL) with 10 queries |
