| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
My player has got an intermittent fault in that it reads the TOC ok, but when playing there is a burst of audio, and then silence and 2 or 3 seconds later another burst of audio.
With no disc, there is a strange faint pulsing audio sound that cycles every 3 or four seconds. Sometimes it works just fine!!! The voltage rails all seem ok Any ideas?? Rich |
#2 |
That's quite an unusual fault. First, a few questions:
- How much experience do you have with electronics, and what test gear do you have? - Did the fault appear suddenly or develop slowly? - Did the fault appear without an apparent reason, or was the player dropped, modified, bought etc.? Those questions aside, it sounds vaguely like a decoder fault, but possible a servo fault. What are the state of the electrolytic capacitors in the player? Are they still original?
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio. |
#3 |
Hi amc184,
The fault has come and gone on three occasions. Started about 6 months ago, but the player doesn't have a huge amount of use. Its ok at present. I am a radio ham, and have built radio gear. I have meters, sig generators, and a nice big Tektronik 851A scope, not storage though. I must confess to not knowing anything about CD players! |
#4 |
The Marantz CD65 being quite an old player, appears to be very prone to IDP connector problems. I ended up soldering many of mine, but I would no sooner fix one than another would start playing up a few months later.( sometimes less)
SandyK |
#5 |
Given it's fundamentals, the most likely cause of trouble is caps. It's always the German electrolytics(Philips, Siemens, Roederstein, etc.) that go first, followed by any Matsushita/Panasonics that might be in there. If it were mine, I'd just go through and replace every lytic cap that isn't already a Nichicon with Nichicon. This and resoldering of any suspect connections is all that this generation of these players needs, 95 times out of 100.
#6 |
Replacing the electrolytic capacitors is a good starting point. Even if they're not causing the player's current problem, they'll give you issues in the future.
It could also be a connector problem, but it's not that likely. Sandy, the CD65DX is quite different to the CD65, it has a mainboard containing most of the player, rather than the CD65's separate decoder and servo boards. Hence there is a lot less cabling. After you replace the capacitors (assuming that doesn't cure the fault) I would start looking through the servo with a 'scope and comparing waveforms and voltages with those in the service manual. PM me if you don't have it and I'll email it to you. This is a somewhat unusual problem, so you'll probably have to do some in depth trouble shooting rather than applying a known fix.
#7 |
Thanks all.
I will replace the caps then. amc184. Thanks for the offer, I'll PM you after I do the caps if that doesn't fix it and scope about as you suggest. Its a 581A scope, a monster but has a good plug in, a type 82. Its served me well fixing old crt tvs. Cheers Rich |
| marantz | alft333 | Everything Else | 0 | 3rd June 2010 04:00 PM |
| Anyone tweaked the Marantz CD65DX ?? | peted | Digital Source | 3 | 16th October 2007 12:13 PM |
| Right speakers for Marantz PM8000 + Marantz CD67-OSE? | betto80 | Multi-Way | 2 | 24th May 2005 03:21 PM |
| Link Between Marantz CD12 and Marantz CD99 | Mesh | Digital Source | 16 | 7th November 2003 06:08 PM |
| Marantz T-1 | stigla | Tubes / Valves | 4 | 17th October 2002 01:11 PM |
| Page generated in 0.09356 seconds (76.83% PHP - 23.17% MySQL) with 10 queries |
