Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th June 2011, 02:15 AM   #1
morbank is offline morbank  United States
Default Headphone Distortion
Hello All, this is my first post here and I apologize in advance for my ignorance and plead that you help right the audio wrongs I have made!
I'm using Nintendo's old Gameboy Color video game system with custom software (LSDJ) to sequence the Gameboys 4 channel internal synthesizer. I wanted to expand from 4 channels to 8 so I added a second Gameboy and enclosed them both in one case and hardwired sync and audio. And despite my ignorance this set up actually sounded really good (musical tastes aside)! Because the Gameboys default audio output is low and thin sounding I decided to hardwire the Gameboys outputs to an old analog Boss parametric EQ guitar pedal. And while this sounds great when connected to a loudspeaker the output is low and extremely distorted when used with headphones.
Below is a description of my blasphemes path (signal path that is):
-I've got two Gameboy Colors (lets call them GB-A and GB-B) each has a stereo headphone output.
-I bypassed both of the Gameboy headphone amps and combined the left signal from GB-A and the left signal from GB-B to make one left signal (GB-A/B Left) and then did the same for the right (GB-A/B Right).
-I then combined the GB-A/B Left and GB-A/B Right signals into one signal and hardwired it to the input of the mono input of the Boss EQ guitar pedal.
-I then split the Boss EQ's mono output signal into two (double mono?) signals and hardwired one to the left input of GB-B' s headphone amp and the other to the right input of GB-B's headphone amp.
What can I do to eliminate the headphone distortion?
I can provide more information, pics and schematic if necessary.
Thanks for reading,
-Clay
Old 17th June 2011, 07:19 AM   #2
Mooly's Avatar
The obvious problem just going off what you describe is that you can not combine any outputs directly.
An output is a "low impedance" feed and you can not just parallel them to combine them as each output "sees" the other a nearly a short circuit. They are fighting each other which may well cause distortion as th output stages are effectively overloaded !
Try adding resistors to provide a little isolation from each output. Value isn't critical, try 1k for example.
So thats four resistors inserted where you have written Lout Rout. That should help with distortion but I can't help but feel the overall sound will be a little odd to say the least mixing four outputs into one (phase issues etc).
A simulation free zone. Design it, build it, test it.
Old 17th June 2011, 07:23 AM   #3
digits's Avatar
Being a guitar pedal it is also more accustomef to see a high impedance load on the output....
Old 17th June 2011, 03:33 PM   #4
@ Mooly, I've added the resistors and they did indeed make a difference but the distortion is still overwhelming with headphones...
Would it work to mix the signals via a mixer? Do you know of a Mixer IC that I could integrate into my signal path?
Old 17th June 2011, 03:36 PM   #5
@ Digits, So I am coming into the guitar pedal with a low impedance load and the pedal is designed for a high impedance load? Is it possible to correct the impedance miss match?
Designing a super low distortion headphone amp. Rainwulf Chip Amps 41 1st April 2011 12:24 AM
Low-distortion Class-A line/headphone buffer linuxguru Analog Line Level 8 13th November 2010 07:00 AM
Guitar Headphone amp with distortion schematics jman 31 Headphone Systems 7 3rd March 2009 02:10 PM
Q: headphone amp with variable distortion vladn Headphone Systems 3 17th February 2008 02:16 PM
Headphone distortion x-pro Headphone Systems 6 29th September 2007 12:53 AM
Page generated in 0.08235 seconds (74.18% PHP - 25.82% MySQL) with 10 queries
