| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
By follow URLs and in the attached files you will find various schematic of reclocking units in front of the DAC IC.
I don't understand the individual pros and cons. At first look the russian approach seems to be the best solution. But I am not really sure. Which of this examples is to prefer? Digital decoding of biphase-mark encoded serial digital signals Reproduction equipment for digital audio Last edited by tiefbassuebertr; 16th June 2011 at 06:50 PM. |
#2 |
First one is based on D-flip-folps... Garbage, it will miss or repeat samples periodically, based on instaneous difference of frequencies (source and local). End result - higher distortions. Some people like them...
Second one is not a reclocking is just a classic SPDIF receiver connected to the PCM100 digital filter. Last one is a schematic for slaving a transport to the DAC. Like that is gonna solve anything... th ejitter from the transport will still be preset at the output (without a bigger RAM buffer than the usual 2K) and DAC will just produce higher distortions than without "slaving". All in all none of the above will offer "jitter reduction". If it was THAT simple (D-latches) all the industry would have already implemented that. Contrary to the general belief, electronic engineers are not morons or memebrs of a secret conspiracy to produce bad sounding devices. Last edited by SoNic_real_one; 16th June 2011 at 10:55 PM. |
#3 |
#4 |
#5 |
Some (most) companies spare a 10c D-flip-flop or capacitor if they can. Some (most) consumers do not notice the difference, because they are not in the position to compare.
#6 |
It's not that trivial a problem to solve, unless you can control the flow of data from the source.
Here's a very interesting article on how to re-clock data from a USB stream using a PLL: The D/A diaries: A personal memoir of engineering heartache and triumph Or you can presumably go for the asynchronous sample rate conversion route, and re-sample the incoming data at the very slightly different clock rate of your DAC, but this would change the 'bits' - though in almost a theoretically perfect way. Something like this: http://www.analog.com/en/audiovideo-...s/product.html Last edited by CopperTop; 17th June 2011 at 07:38 AM. |
#7 | ||
Most simple attempts at reclocking swap one form of jitter for another, typically much worse. Doubling or dropping of samples will happen. As you say, this leads to garbage yet it curiously seems popular. Quote:
#8 | |
As the links I posted above show, the problem is to all intents and purposes solved. It's not something I've ever tried to do, myself, although I sometimes have to 're-clock' other types of digital stream in my work (PLLs are things of beauty aren't they?). Do CD transports ever provide an input to allow the DAC to regulate the flow of data - which would obviously be the simplest and best solution? Presumably this is what happens in the typical non-audiophile CD player that houses the transport and DAC together. Last edited by CopperTop; 17th June 2011 at 11:30 AM. |
#9 | |
Having the DAC regulate data might be better, as up to the DAC output the timing does not matter too much - before that point the data is just that - data. However, the conventional solution tries to deal correctly with the problems: CDP-DAC link introduces high frequency jitter, which the receiver PLL eliminates. In addition, the clock recovery circuit uses the parts of the signal which are least likely to be corrupted. My guess is that most of the jitter seen by the DAC originates in the CD player clock, which is why improving the clock may be worth doing. |
#10 |
"PLLs are things of beauty aren't they?"
Not according to Dan Lavry, he should still have his white papers on his site explaining why PLLs are the spawn of the devil. Always use the DACs clock as the master. Lavry Engineering - Unsurpassed Excellence |
| Eliminating jitter "completely" - Benchmark DAC1 approach | halcyon | Digital Source | 28 | 24th April 2005 07:52 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
| Non os reclocking, I2S and DEM reclocking | Zodiac | Digital Source | 13 | 16th January 2004 11:24 PM |
| JISCO Jitter reduction | Tieftoener | Digital Source | 10 | 31st October 2003 12:09 AM |
| Page generated in 0.12032 seconds (82.49% PHP - 17.51% MySQL) with 11 queries |
