Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th June 2011, 09:59 PM   #1
nad is offline nad  United Kingdom
Default Replacing an original XO & ceramics question
Howdy guys, sorry to ask but I'm in need of an answer quite sharpish as I'm without music
Basically I removed a standard 16.3944 crystal and it's associated 2 x smd ceramic capacitors and replaced them with a discrete clock.
Now I wish to put the original crystal back in which is easy enough but the ceramics (15pF & 18pF) were 2mm by 1mm and far too small for me and my limited soldering skills to handle so the question......
Can I use small ceramic radials instead of the smd's? I will cut the legs back as far as possible. Will there be any implications?
Any answers would be truly appreciated.
Old 6th June 2011, 10:42 PM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
Actually, if you have a fine tipped soldering iron and clean the component pads thoroughly with solder wick, soldering those SMDs is really not that bad.
Using 0.5 mm diameter solder, tin one pad with as little tin as you can get away with. Then heat up this tinned pad while placing the component centered on the pads. Allow to cool. Solder the other pad. Touch up the first pad. Done. If you end up with a solder blob, just wick it off with the solder wick. And use new capacitors of the appropriate case size.
If you still don't want to solder the SMDs, use as physically small leaded caps as you can find and connect them with very short leads. The caps probably go from each XTAL pin to ground, so tapping off at the crystal with one pin would work as well.
~Tom
Old 7th June 2011, 08:41 AM   #3
jcx is offline jcx  United States
you also need something to hold the cap down, the solder surface tension can cause it to stick to the iron or "tombstone" on the pad if you don't hold it down on the pads with a toothpick or dental probe
Old 7th June 2011, 08:54 AM   #4
Thanks for the replies guys, good job.
I've just put a pair of small 22pF radials (available locally) in with the legs trimmed as far back as possible and it all sounds bloody good, back to how it used to sound so I'm happy.
Thanks again!
Old 7th June 2011, 11:38 AM   #5
oshifis is offline oshifis  Hungary
I just wonder why one would go back from external clock to on-chip clock?
Old 7th June 2011, 11:57 AM   #6
marce is offline marce  United Kingdom
Suprisingly, using an external clock with long leads can be detrimental, clock signals should be as short as possible and away from everything else!
Old 7th June 2011, 12:15 PM   #7
There were pros and cons with the 'external' clock, pros being keys and strings sounded more like, well, keys and strings, detail was released which was good within it's own right but put a CD on that isn't too well mastered and the new detail turns to a prominent scratchy hiss. The main reason for reverting back to the on board crystal was the reduction of 'kick' in the lower levels and that just wasn't for me.
Question about replacing amp in KLH ASW10-120 matteos80 Subwoofers 4 18th February 2011 02:12 AM
Replacing xo in AUDIO-GD digital interface john dozier Parts 2 17th January 2011 04:55 PM
Digital XO vs Op-amp XO, which would be best to use in active speakers? MikeHunt79 Analog Line Level 11 16th November 2009 05:06 PM
Zen Amp Original. Question about pdf ! bulrot Pass Labs 3 8th June 2006 02:23 PM
Page generated in 0.09049 seconds (79.89% PHP - 20.11% MySQL) with 10 queries
