Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th June 2011, 09:35 AM   #1
supra is offline supra  Australia
Default JRiver/I2S/TDA1541
Just for the nostalgia , and because it was possible I connected a teradac 24/96 USB-spdif up to the I2S inputs of an old 1541 dac I had in my junk pile, using the I2S connector on Teradak of course.
Worked first time, and has that "nice" 1541 sound, a bit dated ,but better than the spdif input.
The interesting thing is when I play a DAD 24/96 through JRiver the 1541 passes it ok. The JRiver says it is outputing 96k, but all my other dacs will only output up to their limit , which for the 1541 is 16bit/44.1Khz.
It doesn't sound like 24bit/96k , can the 1541 downsample?
Old 5th June 2011, 09:53 AM   #2
Previously: Kuei Yang Wang
ThorstenL's Avatar
Originally Posted by supra View Post
The interesting thing is when I play a DAD 24/96 through JRiver the 1541 passes it ok. The JRiver says it is outputing 96k, but all my other dacs will only output up to their limit , which for the 1541 is 16bit/44.1Khz. It doesn't sound like 24bit/96k , can the 1541 downsample?
The TDA1541 cannot down-sample or do any manipulation. It can operate up to 384KHz sample rate and it will load and convert the 16 most significant bits of an I2S bitstream that has a wordlength exceeding 16 Bit.
So you can (for example) feed the TDA1541 directly a 192KHz/24Bit datastream and you get 192KHz sample rate, but only 16 Bit...
Ciao T
Old 5th June 2011, 02:08 PM   #3
Ciao T
Thank you for a complete and interesting answer.
Music server with TDA1541 (I2S direct) ChuckT Digital Line Level 22 27th August 2010 06:53 AM
FS: TDA1541 twin DAC, USB/I2S receiver, more nl Swap Meet 6 30th April 2010 09:02 PM
Left-justified I2S to Philips I2S Converter curva Digital Line Level 23 19th February 2009 01:50 PM
Oversampled TDA1541(a) I2S format? andrew_whitham Digital Source 25 17th April 2006 07:10 PM
Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input dkj7a Digital Source 1 26th March 2006 05:46 PM
Page generated in 0.06562 seconds (82.47% PHP - 17.53% MySQL) with 10 queries
