| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1 | |
Mrfeedback wrote:
I thought that CD players used the same principle as every other digital storage and communicaitons device uses to detect data through analog.... zero crossing? In other words, the signal may be "analog" (but varying in width), but the bits are actually where the change occurs in the signal, so that there can be little problem from noise. The detector is clocked such that when the crossing occurs within the read window, in coincidence with the fixed clock rate, there is detected a one, whereas if there is no crossing, the result is a logical zero (using an AND gate, I guess). Is this not how CDs work? Jitter is a problem only insofar as the more the jitter, the liklihood is there for misreading a bit, due to varying drive speeds. Well, as far as hard drives and other data stream devices are concerned, that I know of. Please tell me because I really am not sure. It has been a long time since I read how CD data is read, technically, and I am having a hard time finding any real technical documentation. Thanks! Gabe
Gabe CGV Electronics Home of the CGV-300B amplifier on a budget |
#2 |
Ken Clements in "Audio & HIFI Handbook" edited by Ian Sinclair
says: |
#3 |
Image 1 - Idealised clean, HF waveform.
I believe not to believe in any fixed belief system. |
#4 |
Image 2 - SAA7345 Decoder IC HF input.
#5 |
Image 3 - SAA7345 Internals
#6 |
Image 4 - Datasheet quote.
#7 |
Image 5 - CD-63 RF Amp
#8 |
Hi Gabe,
Sorry about delay in getting back to you - weekend, GF, etc. Anyway, if you study the above circuits you will see that they are all single (B+) supply operation. If these supplies is noisy, additional noise is directly coupled into the HF waveform and this may confuse the Data Slicer decision stage, introducing actual data errors or at least timing errors (jitter). I know that this squared waveform is passed into a FIFO buffer that theoretically should eliminate this jitter, but in practice a noisey/jittery HF waveform causes data corruption that may or may not require data error correction or interpolation. The disc spin speed control signal is also derived from the incoming HF waveform, and a noisey HF waveform will cause an overly erratic spin servo error signal. Wild servo currents cause other supplies to be noisey (typical lousy earthing layouts are the main cause) and can cause other feedbacks. In my experience in some past modding, seperated transformer supplies for servo and digital/audio out sections, corrected earthing arrangements, and simply improving supplies to the initial analog preamps and initial processing chips stages is a disarmingly effective improvement. The audio result is to add a calmness - much reduces erratic fine unmusical haze and HF glare/essing. CD43_53_63 Service Manual.pdf is the 9.6M file I downloaded from somewhere yonks ago. In some (most ?) earlier cdps, the initial preamps and data slice/decision stages were discrete and external to the first processor, but I don't have HD copies. If you study the above stuff you should get the point. Other schematics are worth a close look too. Cheers, Eric.
#10 | |
Hi Mrfeedback and all others,
thanks for your replies, but I am still a little confused, especially in light of the following I found at this web site: http://electronics.howstuffworks.com...udio2/95x7.htm Quote:
I guess I am going to have to seek several different publications, and a good schematic, one which breaks down the compoonents a bit more discreetly in order to understand this. Again, thanks so much for all your replies. This is fascinating. Learned much from you. Gabe
| Problem with TL431 regulation, plse help me. | commstech | Digital Source | 27 | 31st March 2008 12:53 PM |
| mrfeedback rattles windows | mrfeedback | Everything Else | 34 | 31st December 2003 10:49 AM |
| Mrfeedback, you are now one of the Enlightened | roddyama | Everything Else | 11 | 5th November 2002 12:48 AM |
| Page generated in 0.11061 seconds (83.45% PHP - 16.55% MySQL) with 11 queries |
