Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Upgrading & modding new Oppos, BDP-93 & BDP-95
Old 30th December 2017, 11:58 PM   #481
dbx01 is offline dbx01  United States
You have 22 voltage regulators on the audio board AND you are using Paul hynes voltage regulators on all 22 regulators?
Do you have any bdp9 porn you would like to share with us?
Old 31st December 2017, 01:05 AM   #482
academia50 is offline academia50  Argentina
Originally Posted by dbx01 View Post
The ess sabre 9028 pro is advertised by ess as a drop-in replacement pin compatible with the sabre 9018.
The sabre 9038 pro is not. It carries an additional 5v input, so you could not directly perform a drop in replacement like you could when going from 9018 to 9028. I read elsewhere that the 9028 is sonically an improvement, but it does not carry a night and day difference between the two.
Understood, it is not compatible then....., thanks for clarifying the point.
I remembered reading this, ( In the link i attached ) apologies :
Clearly we see the ESS Sabre reference DACs in the Sonica DAC (ES9038Pro) and BDP-105 (ES9018) perform extremely well...
Old 31st December 2017, 01:14 AM   #483
Not certain which ess chips the bdp 105 utilizes - the 9018 or the 9028 (pretty certain it is the former since it is just a revision of the bdp-95). The bdp 105 was released before the incarnation of the ess 9038 pro but I believe it was around during the ess 9028 run. It may be possible that later versions of the bdp 105 utilized the 9038 pro. But then oppo would not call it the bdp 105 anymore.
This is speculation on my part but I am pretty certain that is the case, unless someone could prove otherwise.
Old 31st December 2017, 10:32 AM   #484
Coris is offline Coris  Norway
Coris's Avatar
Oppo 105 it use Ess9018 DAC chip. Sonica DAC and UDP 205 it use Ess9038Pro.
Old 31st December 2017, 02:37 PM   #485
Thanks Coris.
Old 31st December 2017, 05:10 PM   #486
audioengr is offline audioengr  United States
How about nichicon low esr caps? They should do just as good of a job as Panasonic caps.
ESR is better on the RIGHT Panasonic caps. Not all the same.
Lelon caps are good too.
Steve N.
The very best in computer audio
Old 31st December 2017, 05:11 PM   #487
Paul Hynes technology. I designed the regulators.
Steve N.
Old 31st December 2017, 05:41 PM   #488
Steve - did you replace all the regulators on the audio board (22 of them?) with your regulators? Are they running in shunt or serial or both? I am still thinking of going with tentlabs regulators for the 3.3v and burson for the 1.2v regulators.
I use Paul hynes ps and regulators on my turntables.
Also, would you mind sharing which caps you replaced on the audio board with your solution of caps?
I've been meaning to upgrade my bdp 95 for quite some time, but other projects have taken precident.
Old 31st December 2017, 08:01 PM   #489
These regulators are serial, some with small pass FETs and some with large pass FETs on heatsinks. They have all been speeded-up, except the analog ones. For Digital, you need fast regulation.
They are not "replaced". It is my product. My mix of decoupling caps is one of my trade secrets, sorry. Maybe if someone buys my component business, they will share this, or after I retire in a few years.
Steve N.
Empirical Audio
Upgrading & modding new Oppos, BDP-93 & BDP-95Hide this!Advertise here!
New Oppo BDP-93/95 and DIY possibilities... Joe Rasmussen Digital Line Level 2 2nd June 2011 03:00 PM
Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? gaetan8888 Everything Else 0 5th April 2010 06:16 PM
Oppo BDP 83, and Tube amps ronton3 Digital Source 2 8th March 2010 10:31 PM
SONY BDP-BX2 doesn't power on yzriver Digital Source 1 24th February 2010 08:19 AM
Newest OppoDigital.com BDP-80 - opinion FastEddy Digital Source 1 20th February 2010 01:09 PM
