Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Upgrading & modding new Oppos, BDP-93 & BDP-95
Old 4th May 2013, 10:32 PM   #351
rolleiman is offline rolleiman  United States
Hi all,
I will not highjack this great thread but wanted to see if anyone has a schematic/SM for the Oppo DV-983H? I have one that I would like to Mod and create a thread to document the progress.
Thanks Team,
Jerry
Old 9th May 2013, 03:06 PM   #352
Coris is offline Coris  Norway
Coris's Avatar
Originally Posted by sound24 View Post
I want to switch off the audio-board in OPPO-95.
Because without fun Oppo gets hot after 1-2 hours of using.
Clued some 478 socket radiator (of course), drilled more holes in the bottom but it's not enough.
I use OPPO mainly as a transport, so I want to switch off the Rotel trafo with 110/220v switch on the rear panel.
But what to do with emulating signal (OVP-TEST)?
I tried OPPO without upper board, and it played CDs normally, but I'm not sure in full functionality (BR etc).
I think is not easy to just remove the analogue power supply, or cut it off. OVP-TEST is possible to be simulate it with the same tension value out from a potentiometer. If I remember well this signal should give information about over voltage in power supply, or if is missing, the player will not start.
Oppo 95 should have a forced ventilation, as it is quite much generated heat inside. If you supplement the heatsinks there is not much help. It get cooler maybe that targeted component, but the heat it still be inside the enclosure. Something it may bring out that heat. A fan... If you use an speed regulator for computer fans, it may help quite much to decrease/eliminate the noise from that fan. The same if you use a low noise fan.
There are parts of that analogue PSU rails which are used to power the DACs and its oscillators. If the oscillator it not work, the player will not boot up...
It may help to replace that Rotel transformer with another one having lower tensions on its output. So the difference between power delivered from trafo and the needed regulated tensions/power, decrease enough to not generate so much heat. I did like this actually with good results. That trafo deliver 22vAC, and the needed regulated tension is +/-12v or so...
If you are so decided to not use the player, but only the transport in it, you may lower the analogue power quite much. Is not so important in such case if the regulated tensions are not well regulated... to be used on the opams, but it may be good enough to generate with it a good regulation for the lower tensions (3,3v, 1,8v, 1,2v and so on). The power for such low power rails it come from that mainly 22vAC from the trafo... Quite stupid design!
So you can replace the Rotel trafo with one which deliver f. ex. 9-10vAC. You will have then approx 14vDC on regulators, which maybe will not be enough to get a good regulated +/- 12v power out of the analogue PSU, but will not cause dissipation on regulators. Such low AC voltage is good enough to get the lower tensions very well regulated to have an working player. I hope I was enough clear to make me understood...
You may measure carefully and take the right decisions, before proceed to such mod. But it may be a good solution at last to get rid of that heat and having well working (only) transport...
To be honest, my opinion is that you have done wrong choice investing in 95 to use it only for its transport. I could be much better and much cheaper to buy an 93. They have similar transports, but big difference in audio stage, and power supplies... and heat dissipation.
Old 18th June 2013, 04:40 PM   #353
Smiffy is offline Smiffy
Ta Coris for helping everyone on this thread
The Power supply
Is it worth changing the caps for the output?
I have spare black gates and os cons
Oscons for digital 5v for the video board.and black gates for the audio board?
Old 18th June 2013, 09:26 PM   #354
Coris's Avatar
The Power supply
Yes it is! Better quality and more capacity on 5v is good. On analogue one, more F is worth too...
Old 19th June 2013, 05:29 PM   #355
Ta Coris
Will fit the biggest I can.quite a bit of room under the pcb as well.Thinking of going analogue power supply in the future.Found an R core transformer from a Sony Minidisc player with 15-0-15v,8-0-8v and 4.5-0-4.5v
Hopefully if it ran a mini disc player it should have enough current for a blue ray player.can't find any specs on it though
Smiffy
Old 23rd June 2013, 05:36 PM   #356
Replaced the two 220uf for the +5 digital line with 470uf oscons.havent watched a blue ray yet but a marginal increase in sound quality(Slightly cleaner highs and seemingly more power in bass)
Have checked the psu pcb and would appear CE8 does -15v and CE12 does +15v with ground on the connector in the middle.
Somewhat confused over CE5.Would appear it goes to an unused pin on the digial video power supply connector and to the +5v digital supply ground via a 10K resistor.
As I am nowhere near an electronics expert any ideas anyone?
Ta for any help
Will do the +-15v with black gates.Space is a bit limited though
Smiffy
Old 23rd June 2013, 05:41 PM   #357
Silly me
found it
Would appear to be a +15v digital supply.Caught me out cos the writing was on the opposite side to the rest
Smiffy
Old 24th June 2013, 07:28 AM   #358
Coris's Avatar
On Oppo 95/105 the switching PSU deliver +5v out. The rest of the tensions it were used in 93/103 type of players, but not in these with analogue PSU. Mainly is +5V you should pay attention if you have 105 model. Right decoupling/filtering on +5v should improve enough both picture and sound. Specially picture stage is very sensitive to the noises coming on power rails... Removing these noises is very noticeable in a more clear/detailed picture. The sound it will be specially improved by other means, but a clean +5v is quite important.
Old 24th June 2013, 02:54 PM   #359
Ho Coris
I have the 93.
I have replaced CE6 and CE19 with 470uf sanyo oscon but am looking for 1000uf as it occurs I can use 10v instead of 16v.That way I may be able to mount two underneath the pcb giving me 2000uf on each line instead of 220uf
16v capacitors on the analogue I think is pushing my luck a bit so will try and find 25v.
Ta for the help
Smiffy
Old 24th June 2013, 05:53 PM   #360
ps do you think I can get away with 6.3v caps on the 5v digital line?
Smiffy
Upgrading & modding new Oppos, BDP-93 & BDP-95Hide this!Advertise here!
New Oppo BDP-93/95 and DIY possibilities... Joe Rasmussen Digital Line Level 2 2nd June 2011 03:00 PM
Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? gaetan8888 Everything Else 0 5th April 2010 06:16 PM
Oppo BDP 83, and Tube amps ronton3 Digital Source 2 8th March 2010 10:31 PM
SONY BDP-BX2 doesn't power on yzriver Digital Source 1 24th February 2010 08:19 AM
Newest OppoDigital.com BDP-80 - opinion FastEddy Digital Source 1 20th February 2010 01:09 PM
Copyright ©1999-2017 diyAudio
