Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Upgrading & modding new Oppos, BDP-93 & BDP-95
Old 23rd February 2013, 01:36 PM   #341
Coris is offline Coris  Norway
Coris's Avatar
Originally Posted by Joe Rasmussen View Post
Well, I have done and also finished my Oppo 95 with double-SAW.
I have also tried the Crystek - now there are three of us that have done the Crystek vs SAW comparison... and the winner is....
Not so quick.
Well, the SAW actually.
I have set it up it right now that I can compare the two easily and I will be able to do the comparison for other people in the room over the near future, and get more feedback.
Cheers, Joe
I only agree with you (I have the same opinion) that SAW oscillator give a more precise/accurate sound. More than an Crystek, I mean.
I still want (waiting for) to hear from someone who used an SAW saying that it were bad experience...
But Joe, it may be in place 3 SAWs... For DAC, 25Mhz, 27Mhz (54/2). I`m excited to see what it may happen with an 27Mhz in the right place...
Old 9th March 2013, 06:20 PM   #342
Smiffy is offline Smiffy
Any help for the BDP93 power supply?
Wish we could get a schematic
In the power supply does caps CE8,CE12 and CE5 feed the dac and audio board and CE6 anhd CE19 feed the video board?
Ta for any help
Smiffy
Old 16th March 2013, 05:26 PM   #343
Looked underneath
Correct.
Old 4th April 2013, 04:23 AM   #344
jumiferriol is offline jumiferriol
Default capacitors OPPO 95
Originally Posted by Coris View Post
3,3v powered oscillators.
HELLO CORIS.
I want to modify the output stage IN OPPO 95.
I would change the electrolytic capacitors, to improve the audio output may replacement.Jantzen Z CAPACITORS SILVER, 3.3 UF.
I read that you suggests many tantalum capacitors.
you can help me??? excuse my bad English, I speak Spanish.
BR
JULIO
ARGENTINA
Old 12th April 2013, 08:54 AM   #345
jbxsamy is offline jbxsamy  France
Hello,
Someone will drive improved the audio and video playback in the OPPO 93.
If so how?
Old 12th April 2013, 01:41 PM   #346
Default oppo 95 out capacitors
Originally Posted by jbxsamy View Post
Hello,
If so how?
Hi Samy.
I have understood that shorting the capacitors in the output stage there is an improvement, as you run a curtain of impairment.
I do not make any changes, do not quite understand this.
Some argue that just have to be shorted and other metal capacitors should be placed 3 to 4 MF, Jantzen type audio, Mundorf, etc..
always on the output stage.
When you can expand a little more information I will perform the test and post the results.
br
Julio
Old 17th April 2013, 01:06 PM   #347
Coris's Avatar
Originally Posted by jumiferriol View Post
HELLO CORIS.
BR
JULIO
ARGENTINA
Hi Julio
You may know that the 95 model it not have caps on outputs (is DC coupled).
About many tantalum caps, those are used to decouple power rails for some chips involved in signal processing.
Old 17th April 2013, 01:51 PM   #348
Hello,
My 93 NXE is already super modified.
Full power linear in OCXO clocks, OS CON and Nichicon capacitor on the motherboard.
The only thing I have not changed is the drive.
I would like to improve.
If it is possible.
Old 18th April 2013, 04:01 AM   #349
steven2583 is offline steven2583  United States
I have a 93. If I just change out the power supply to a good linear power supply how big of an improvement in Video and Audio should I expect if I connect it to a sound processor with an HDMI cable?
Old 4th May 2013, 11:55 AM   #350
sound24 is offline sound24
I want to switch off the audio-board in OPPO-95.
Because without fun Oppo gets hot after 1-2 hours of using.
Clued some 478 socket radiator (of course), drilled more holes in the bottom but it's not enough.
I use OPPO mainly as a transport, so I want to switch off the Rotel trafo with 110/220v switch on the rear panel.
But what to do with emulating signal (OVP-TEST)?
I tried OPPO without upper board, and it played CDs normally, but I'm not sure in full functionality (BR etc).
Upgrading & modding new Oppos, BDP-93 & BDP-95Hide this!Advertise here!
New Oppo BDP-93/95 and DIY possibilities... Joe Rasmussen Digital Line Level 2 2nd June 2011 04:00 PM
Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? gaetan8888 Everything Else 0 5th April 2010 07:16 PM
Oppo BDP 83, and Tube amps ronton3 Digital Source 2 8th March 2010 11:31 PM
SONY BDP-BX2 doesn't power on yzriver Digital Source 1 24th February 2010 09:19 AM
Newest OppoDigital.com BDP-80 - opinion FastEddy Digital Source 1 20th February 2010 02:09 PM
Copyright ©1999-2017 diyAudio
