Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Upgrading & modding new Oppos, BDP-93 & BDP-95
Old 21st February 2013, 05:03 PM   #331
qusp is offline qusp  Australia
qusp's Avatar
a slow difference that happened over a week of time? thats never going to be easy to hear; but anyway clocks have pretty much constant power draw so it will just work till it doesnt. I dont think it will have a regulator...
I have run it this oscillator on battery since it were full charged (4,2v) and until the oscillator it stopped itself because to low power (approx 3,6v)
It seems that this oscillator have an internal regulation system for its power. Even though this quite big variation for tension at its power pin (3,55v - 2,9v)
so which was it? or you have a passive filter after the battery that lowers voltage?
BTW, you might try twisting the output wires... as they are, they are both receiving and transmitting noise due to parasitic inductance. but of course you will say you dont hear any noise, so it must not be happening. twisting balanced wires is a very basic requirement to allow the CMRR to work properly. you dont have a ground wire with the SE outputs? they will also act as antenna.
for someone that goes out of his way to replace everything with SMD parts, you dont seem to care much about inductance or loop area.
Old 21st February 2013, 09:01 PM   #332
Coris is offline Coris  Norway
Coris's Avatar
In first quoted phrase (4,2v - 3,6v) it is about battery voltage. The second one refer to the voltage at the power pin of the oscillator.
There is an resistor in between battery and oscillator Vcc (as you can see in the picture + a fuse) to lower the tension to the specified levels for oscillator, and limit the current to the max specified too.
I was enough surprised to observe that even the quite large Vcc tension variation at the SAW oscillator pin, I could definitely not register any change in the quality of the resulted sound... Or I can say that the SQ improvement it were obviously over all this tension level variation, until the oscillator stop it self because to low Vcc.
Charging the battery every time the player is off, reduce much the Vcc variation. Everything is fine so far! I plan to go deeper in this experiment (but using another board and hardware configuration), to find out what is actually going on.
There is right your observation about battery connection wires. But those are also short enough. In fact my worry is actually the large battery surface which it may capture better the noises as an antenna... But at last it is working all very well...
Of course, what you can see in the picture (battery powered) is not at all an professional designed circuitry. Is only experimental "construction". If I should design all this on an dedicated board, will for sure do not look like you see in the picture...
Else it is used the ground plane of the original design, and the battery -/GND is connected with an enough big section silver wire to the oscillator GND point. The rest of the wires there around, goes on the other side of the board and further to the charger(s). The relay separate all of.
No matter the lack of " professional design", the result is obviously: it sounds much better this way.
Old 21st February 2013, 09:36 PM   #333
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Coris, in your Oppo 95, what 25MHz oscillator are you using?
I would love you to try the 50MHz SAW available now from Farnell/Elem14 and use the divide by 2 "4040" chip also available from them (get the 90MHz version).
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 22nd February 2013, 07:04 AM   #334
Coris's Avatar
Yes, I know I should do it, and I just thought at that. I have bought actually the SAW 50Mhz oscillator. But... you know for sure that is not easy to work with that board... It were already an numbered times I have mounted/unmounted that board, and at least I got tired to do this... I just want to have that player mounted/working as is modded per today, to go further to the 105 model.
I have an quite good specified 25Mhz Fox oscillator there, so I think it will be to try an 50Mhz SAW another time...
Old 22nd February 2013, 10:57 AM   #335
Coris's Avatar
I think to try/change that 25Mhz oscillator after I will get the 54Mhz one. They said will ship my SAWs 54Mhz batch in April.
So the plan is actually change out both oscillators which it clock the main processor. Then I hope I will be finish with 95 model...
Old 23rd February 2013, 07:51 AM   #336
drdupery is offline drdupery
btw, some rechargeable batteries could be quite noisy
different configurations of regulators and their noise figures including some types of batteries
Simple Voltage Regulators Part 1: Noise
Old 23rd February 2013, 10:36 AM   #337
Coris's Avatar
Thanks for the 9 y.o. (or more) informations...
BTW, here is not about using lead-acid rechargeable batteries.
Just think to have an Oppo player which it need to refresh it the acid time to time, add some distillate water to have some smooth sound from the plaid BD, and so... Maybe testing too it`s oil level in the gear box of the main processor...
Old 23rd February 2013, 10:52 AM   #338
qusp's Avatar
no i'm not talking about them, i'm talking about your IV output wiring connecting to the XLR and RCA outputs, its quite literally a large antenna and without twisting the wires, you not only lose or significantly degrade the CMRR that is the whole point of having a balanced system, but they become a big receiver and transmitter of noise and its not small, it will make quite a nice pure silver antenna connected to your most critical analogue stage, it will pick up any RF the clocks put out and transmit its own, the RCA especially. twist the +/- dac XLR output wires and give the RCA a ground all the way and connect at both ends, not just from one end for a short portion before the ferrite. youve made the loop area of the outputs about as large as you could possibly do, it should be as small as you can possibly do.
Old 23rd February 2013, 11:01 AM   #339
Well, I have done and also finished my Oppo 95 with double-SAW.
I have also tried the Crystek - now there are three of us that have done the Crystek vs SAW comparison... and the winner is....
Not so quick.
Well, the SAW actually.
I have set it up it right now that I can compare the two easily and I will be able to do the comparison for other people in the room over the near future, and get more feedback.
Sorry, whatever conventional measurements say, but the SAW is simply able to resolve more detail, the Crystek is slightly soft and homogenises fine detail together. The SAW is rythmically stronger, it is clearer and separates sounds better, especially acoustic and spatial separations. It is less coloured, there is a slight mid-emphasis in the Crystek that is not there with the SAW, and an additive effect that the SAW does not suffer.
To Terry, I don't know what is going on, but I know it defies the measurement logic. In a way, the SAW is a faster type of oscillator - it can be made for very high frequencies, and it sounds faster too. Maybe the two have no connection...?
But the "additive jitter" theory, it just doesn't seem to describe what I am hearing, the SAW is simply more precise.
I have to say, I would have just loved the Crystek, and if it wasn't for the SAW, I would have heard no shortcomings.
Both are easily the best I have heard on a Sabre DAC. Both are 100MHz.
I am going listen to both some more, with others having an input. So I am open to the possibility that some may prefer the softer presentation, as it is very smooth? But I want the extra way that the SAW just sounds more REAL to me.
So there you are.
Cheers, Joe
Old 23rd February 2013, 12:26 PM   #340
Coris's Avatar
Well...I know how you think, and I agree with the theory which is based your above comment on. But...
There is about few cm wires to connect the DAC to the RCA. There is about very low impedance output from the opamps... Induced HF noises in those few cm output wires, and then further through cables to the amplifier???!!! How high level it should have those "noises"? Volts?! What it happen with those noises further? Get in to the amplifier and it will be amplified?! I never experienced an audio power amplifier which is capable to amplify in radio spectre. Did you? So, that supposed volts HF noises will be amplified to tens of volts further by an audio power amplifier??!!! All this it sounds like "mad science", don`t you think?
Now about facts: I measured what is coming out from that RCAs. I have there 32mV which are residual HF noises from the DAC chip. Those noises are in few Mhz spectre and are right at the opamps outputs 680mV (I have no any filter in between I/V and output buffer). I succeed it to reduce (no filter) this HF noises to that 32mV on RCA point for an usefuly audio signal of max 13-15Vpp.
Further, my RCA cables are not twisted at all, and even "worse", not even shielded... Can you imagine? At least are not very long either. Only 30cm silver wires which get right in to the (one stage) power amplifier. I experimented a lot in this cable field, and I found that this way is best. My cable have now approx 20pF. Do you know what happen when is to shield a such cable or twist it?. You get at once more than 100pF on a quite short of such. I do not know if you can hear the difference between an signal through an 100 -200pf cable and an 20 - 30pF one, but I can. I can even assure you that is quite big in the favour of the low capacity one. I couldn`t find yet the theory to explain you why...
XLR connections are made, but I do not use it yet that output...
As you said before, you mean that I have a huge gain in my whole system. Maybe... but I think is just right how it is, to give me that performances I want to have from it. So, how you see in the picture, with those very degraded CMRR, huge ground loops, not even shielded connection cables, huge system gain, etc., I have absolutely no any noises out of that system, and it is sounds just exceptional. My improvements over years on this system it were step by step, on every component of it. It were corrected every fault or imperfections, and how it sounds now is the best I could get. I can only tell you that I`m quite demanding in this field...
Upgrading & modding new Oppos, BDP-93 & BDP-95Hide this!Advertise here!
New Oppo BDP-93/95 and DIY possibilities... Joe Rasmussen Digital Line Level 2 2nd June 2011 03:00 PM
Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? gaetan8888 Everything Else 0 5th April 2010 06:16 PM
Oppo BDP 83, and Tube amps ronton3 Digital Source 2 8th March 2010 10:31 PM
SONY BDP-BX2 doesn't power on yzriver Digital Source 1 24th February 2010 08:19 AM
Newest OppoDigital.com BDP-80 - opinion FastEddy Digital Source 1 20th February 2010 01:09 PM
Copyright ©1999-2017 diyAudio
