Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Upgrading & modding new Oppos, BDP-93 & BDP-95
Old 18th October 2012, 02:32 PM   #251
Adhara is offline Adhara
Originally Posted by Coris View Post
Now it only remain to add an better heat sink over the main processor to experience an even higher video result...
Really ?
Can you pease give more details ?
something to buy? what ?
Old 18th October 2012, 04:55 PM   #252
Coris is offline Coris  Norway
Coris's Avatar
Originally Posted by Adhara View Post
Really ?
You may find an idea (for BSP95) in this thread...
http://www.diyaudio.com/forums/digit...p-95-a-10.html
In your case maybe will not fit exactly this way to do it, but anyway the point is about to find a solution to attach a better and more effective heat sink for that processor... Even an enough big surface aluminium plate in direct contact with the chip, will help much the processor to cool down...
Old 20th October 2012, 09:33 AM   #253
Extreme_Boky is offline Extreme_Boky  Australia
Default OPPO BDP 105
coax, optical and USB in (asynchronous!)
HDMI in (!)
not bad....
Boky
Old 25th October 2012, 04:39 PM   #254
Coris's Avatar
Oppo say that the new model "OPPO BDP-105 is designed from the ground up...).
This it seems to me as very interesting. Waiting for the inside pictures of this new model.
Personally I think it will anyway still enough to be modified and upgraded in this model too... But is better to start those upgrades form a higher base level...
We will see...
Old 26th October 2012, 01:17 AM   #255
Larry Ng is offline Larry Ng
Default Pictures of 103
No 105 now , 103 hopefully gives you all some idea .
Larry
Old 26th October 2012, 07:40 AM   #256
Coris's Avatar
Larry
BDP105 it should be more advanced than 103 (as 95 is comparing with 93), and therefore more interesting. Even more, if is true that is designed from the ground up... It were quite many design faults in the 95 version of this player.
BDP103 is only a lifting up of the 93 model...
Old 26th October 2012, 11:02 AM   #257
Larry
It seems OPPO has finally produced a decent piece of hardware. I really like what I see here. Nice switched mode power supply with decent filtering, properly aligned connectors between power supply board and analog board for shortest connection & decent interconnecting wires. What I see for the first time in OPPO hardware is the local regulation positioned exactly where it should be - next to analog IC's and DAC. Same applies to other IC's for video processing.
Lets see what 105 looks like inside. Full blown DAC with a-sync USB, universal player and HDMI input (and headphones out socket) classify this OPPO as one of the kind in the whole industry. It could easily become my first OPPO...
Boky
Old 26th October 2012, 02:46 PM   #258
Coris's Avatar
Boky
You may precise that you were sarcastic in this part of your post (it seems like this to me)...
Else, your critic is just right. BDP103 (as 93) are quite cheap devices and the care of Oppo for that professional build/design in this player is not quite high... It work for that money they sell it...
Old 31st October 2012, 06:11 PM   #259
Coris's Avatar
A new thread is opened for the new model BDP105:
http://www.diyaudio.com/forums/digit...ml#post3222646
Old 2nd November 2012, 04:25 PM   #260
jbxsamy is offline jbxsamy  France
Hello;
I would like to know if the change AOP analog output card NuForce Extreme Edition by Burson HD AOP can provide more real.
Thank you in advance for the answer.
Johann
Upgrading & modding new Oppos, BDP-93 & BDP-95Hide this!Advertise here!
New Oppo BDP-93/95 and DIY possibilities... Joe Rasmussen Digital Line Level 2 2nd June 2011 04:00 PM
Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? gaetan8888 Everything Else 0 5th April 2010 07:16 PM
Oppo BDP 83, and Tube amps ronton3 Digital Source 2 8th March 2010 11:31 PM
SONY BDP-BX2 doesn't power on yzriver Digital Source 1 24th February 2010 09:19 AM
Newest OppoDigital.com BDP-80 - opinion FastEddy Digital Source 1 20th February 2010 02:09 PM
