| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 | |
You may be right too when you talk about the price and the corresponding quality, but here I personally am not fully agree with you. First Oppo do not "give" a product out on the marked, but they sell it and one have to pay for it. When you pay for something you may also pretend that quality level you expect it for that you pay for. Here is the difference: somebody can be satisfy, somebody not, for the same price one it pay... But, anyway this is something else... In my opinion, with almost the same price, this player could be one of the rally best on marked... There is about design here, not about (or less) about components... The design costs is included in this 1000$ class price they sell the player. The design could be much better and not so unprofessional how it is in this case. This is only a big shame for Oppo as a high end products company.... I just measured yesterday an 0.5mV DC level between the GND point input from analogue power supply on the audio board, and the GND point of the final output op amp on the same board... This voltage level on the GND plane is variable as the measurement point could be near or quite far from the main (analogue) power supplies. As known this output board of BDP95 is very (unnecessary) wide. So, what for use an low noise power supply with eventually nV noise level, when one have a possible 500µV noise level between different points on the GND plain? I still think that the best solution is in this case, using of local power supplies/regulators (shunt regulators), quite near to the corresponding stage/opamps. I will try to find a solution for corresponding modifications in this field... Last edited by Coris; 24th August 2011 at 07:28 AM. |
#42 | |
the low noise regulators should definitely be located very close to the IC's.... the long power supply traces between regulators and IC's on BDP95 analog board is probably the biggest flaw of the design... this can be compensated somewhat with the correct local decoupling capacitors' values / types / placement location…. I also don’t like polystyrenes… still, I think that is a lot of a player for $1000. Boky |
#43 | |
By the way, I can see that interconnection between audio board and the motherboard is made by a flat cable which use only the pins on one side of the respective connectors. On the audio board are printed names of signals for both sides of that connector. It could be for an future upgrade of the system, or can some of the another signals be valid too for this model? I just think about what to connect those boards with a two side flat cable... Can have the SATAx signals named on this board`s main connector interface, something to do with SATA interface? Have somebody get in this before? |
#44 | |
One thing I want to point out is that the 317/337 regulators require a minimum of 3.5V across them to meet their full specifications (based on specs and experience) and when you factor in 10% low line as a design criteria that puts the raw dc input voltage to the regulator at slightly over 20V for nominal line - so even the transformer output voltage seems a reasonable choice if you want to maintain good regulator performance over temperature and input voltage range.. The one one issue I would quibble with is the oscillator supply, and that obviously from the bean counters perspective was probably at the point of diminishing returns. Seems competent enough even if not brilliant..
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#45 | |
Let's forget about the cost/performance view but only from perfectionist view. Just interested to know what would you have done to the power supply in your tweak ?
Alan |
#46 | |
I`ve used instead the Twisted Pear shunt regulators power supplies. I replaced too the Rotel toroid, with two separate toroids. It was fine to have the Rotel trafo in his place, but I need 3 AC sources (for +/-15v PSU and +9v (12v). Those TP shunt power supplies are very good, but it seems that are not quite in right place in this case. They get too hot for the volume of this player enclosure. So, I think I will go back to the classic regulators as primary PSUs, and then I will use shunt regulators locally, near every stage. I think this is a much better solution, and a less heat dissipation. Please note that in case the original PSU is changed with another one, one have to simulate the signal used by Oppos designers to give to the main processor the message that the power is OK, or something like this (I`ve not investigated yet this very close. I have other priorities...). This signal is an 1,5v DC level (OVP-test). I`ve used an potmeter to create this level from the 9v new PSU. Is not necessary to be exactly 1,5v. It works well for me even with an half of this level... Last edited by Coris; 25th August 2011 at 05:04 PM. |
#47 |
Referring to my previous posts and attached pictures.
I have to say that I`ve abandoned the idea to use the shunt regulator power supplies for my BDP95. At last two of the earlier pictures here do not reflect the reality for today... These shunt power supplies are good enough, but not in this case, when the enclosure is quite full and the ventilation is not adequate for such heat dissipation. I just build it from scratch two another (serial) power supplies based on LM2991/2941 and placed then on the same aluminium plate. I found an R core 40W transformer which deliver 2x15v/9v AC. I have now +/-15v for the output stage. I used the on board regulators, modified for adjustable output, and I feed the I/V stage with +/-12v. +9,5v for the rest. These new power supplies provide a very good stabilization and the temperature on the heat sink do not exceed now 28 degree. This is very well! Before I had to struggle with 50 degree... With a fine tuning of these supplies and right set up for the offset level in I/V stage, I have now an offset on the RCA output as low as 0,2mV. I think now that the best solution for power supplies in this case is to use as primary supplies the serial one, and have local shunt regulators right beside every stage involved in audio processing (digital/analogue). By the way, I use now a 133,3 Mhz clock for ESS9018 and local shunt regulators for AVCC of the chip and an shunt regulator too for the clock oscillator. The I/V and output stages are also modified... Now, the finally result of the audio stage is not so easy to describe, but in one word is just unbelievable. Last edited by Coris; 16th September 2011 at 09:22 PM. |
#48 |
What shunt regulators are you using on the DAC and clock? Schematic?
#49 | |
I`m using TL431 and schematics are right out from the datasheet. Nothing very special this time. But I have to make a correction referring to my previous post and after reviewing my papers... I actually have been using for ESS9018 - AVCC two low noise regulators (L/R) based on MIC5209, also schematic from datasheet. In my opinion, very important is decoupling/bypassing capacitors soldered closest as possible to the load/chip pins. I have to say too that the BDP95 mods was more as an experimental project for make my self an impression about ESS9018 capabilities. As this Oppo project is now almost finish, I will focus more from now on on Buffalo (I got it one in the last time...). With this kit/PCB is more easy to try new experimental levels, trying better solutions, and much more easy to scope and measure the parameters... After I took it a very closed look on OPPO`s BDP95 I can only say that I`m very, very disappointed by the Oppo design of the audio dedicated stage/board and it`s power supply. |
#50 |
You are right - dear fellow Sydney sider.
But the single most worst source of noise in digital players does NOT come from the power supply. NO? It comes from the DAC itself. A bit like getting stuck in a hermetically sealed room. We tend to pollute our own environment and so we need ventilation. Ventilation is of course not the answer here. ![]() But the question is how you are going to treat THAT noise as well as the PS noise. The best solution is to shunt as much noise as you can into the groundplane at lowest Z possible, and also form a 2nd order filter from the PS. That way we treat both the primary and secondary sources of noise. But very few actually do this or even aware that it should be done. I repeat, the primary source of worst kind of noise comes from the DAC itself. I can demonstrate an Oppo that does just this, has no post-DAC active NFB circuitry and other niceties, so we are talking something fully fleshed out. Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
| New Oppo BDP-93/95 and DIY possibilities... | Joe Rasmussen | Digital Line Level | 2 | 2nd June 2011 03:00 PM |
| Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? | gaetan8888 | Everything Else | 0 | 5th April 2010 06:16 PM |
| Oppo BDP 83, and Tube amps | ronton3 | Digital Source | 2 | 8th March 2010 10:31 PM |
| SONY BDP-BX2 doesn't power on | yzriver | Digital Source | 1 | 24th February 2010 08:19 AM |
| Newest OppoDigital.com BDP-80 - opinion | FastEddy | Digital Source | 1 | 20th February 2010 01:09 PM |
