Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th October 2012, 09:42 PM   #241
jbxsamy is offline jbxsamy  France
What is the best link between the OCXO and the motherboard?
Coaxial; Bybee quantum or other?
Thank you in advance for your advice
Old 11th October 2012, 06:21 AM   #242
Coris is offline Coris  Norway
Shortest as possible coax should be the best. If is not about an quite big oscillator PCB, then mounting the encapsulated OCXO right over/beside the clock input pad it could be much better. In such case is not necessary any coax, but only few mm long wire...
Old 11th October 2012, 10:58 AM   #243
Default synchronic clock.
Does sombody tried a 27Mhz clock for the video times two or four for the dac?
(Or 54 divided by 2)
In that manner you can use one after market clock to update performance for video and audio.
Old 15th October 2012, 07:26 PM   #244
I want to know which site to buy quality wire for the inside of the cabler OPPO power to different cards.
Thank you in advance.
Johann
Old 16th October 2012, 08:55 AM   #245
Hello,
Who knows what is the frequency of the VCXO on the map The OPPO 93 Analog NuForce Xtreme Edition and voltage?
Johann.
Old 16th October 2012, 04:02 PM   #246
Johann
I can not see that you may need some special wires for such power connections. It works very well to use the normal coper wires, with a correct section for the current needed... Another better way is to use in parallel 2-3 wires for the same connection. It lower the resistance of resulting connection. Oppo already use this way to connect the power supply output with the rest of the devices.
On the signal path is worth to use better wires, such silver or silver coated coper.
Old 16th October 2012, 07:35 PM   #247
I have one last request.
is that someone has installed a digital input to the analog card to use the DAC live?
OPPO is my NuForce Xtreme Edition and I want to connect my MAC NuForce DAC.
Old 17th October 2012, 11:47 PM   #248
Hi guys,
Just finish to tweak my Oppo 93. Here below for a pic.
Old 18th October 2012, 12:03 AM   #249
Old 18th October 2012, 11:27 AM   #250
Now it only remain to add an better heat sink over the main processor to experience an even higher video result...
New Oppo BDP-93/95 and DIY possibilities... Joe Rasmussen Digital Line Level 2 2nd June 2011 03:00 PM
Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? gaetan8888 Everything Else 0 5th April 2010 06:16 PM
Oppo BDP 83, and Tube amps ronton3 Digital Source 2 8th March 2010 10:31 PM
SONY BDP-BX2 doesn't power on yzriver Digital Source 1 24th February 2010 08:19 AM
Newest OppoDigital.com BDP-80 - opinion FastEddy Digital Source 1 20th February 2010 01:09 PM
Copyright ©1999-2013 diyAudio
