Upgrading & modding new Oppos, BDP-93 & BDP-95 - Page 18 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th August 2012, 07:17 AM   #171
Joe Rasmussen's Avatar
Originally Posted by Jae Hong Lee View Post
I am looking for thin , but good quality coaxial cable for connecting OCXOs.
Is there some recommendations?
I use a hard twist of Kynar wire, silver-clad copper. Not the cheap Taiwanese Kynar stuff - but you have to buy 100M at a time and its not cheap. Works well.
Cheers, Joe R.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 27th August 2012, 07:26 AM   #172
The ideal cloack wave form is retangular.
See the change !!
It is measured of 25 MHZ clock
Old 28th August 2012, 08:21 AM   #173
Hi Coris
What brand 125MHz are you using on the Sabre DAC?
May I suggest you try one of the new "SAW" Oscillators (doesn't mean it has a saw shaped output).
SAW stands for "Surface Acoustic Wave".
I would like you to try this one from Element14 (Farnell), part number 1907485 - described as "low jitter" etc, but reputedly has a noise floor -12dB to that of standard oscillators. And they are not expensive to try.
Here is the PDF file: www.farnell.com/datasheets/1563925.pdf
For info on SAW type oscillators: SAW Oscillator
Cheers, Joe R.
Old 28th August 2012, 12:03 PM   #174
See the change !!
Actually, the shape of the clock oscillator does not translate in to how good the oscillator is... in fact, the shape means nothing; maybe that the CRO probe you usedís been calibrated ok...
Here and "There" you'll find a lot of info on what constitutes a good clock oscillator.
I have attached the pdf document that explains what specs are important, and how to measure them. This should be the starting point. I used these caned oscillators almost 10 years ago -> they were top of the range back then.
Boky
PS
Due to the file size limitations, I had to extract only the most important page, page 1 of the pdf....
Old 28th August 2012, 04:01 PM   #175
Coris is offline Coris  Norway
Coris's Avatar
Originally Posted by Joe Rasmussen View Post
Hi Coris
Cheers, Joe R.
Hi Joe
Thanks for the infos.
There was a time when I used an 125Mhz oscillator in my experiments with Sabre DAC. There was not about an high end oscillator, but an quite ordinary one with the best parameters I could find for a reasonable price. It worked very fine.
Then I used some matched frequency oscillators (multiple of 48/44,1 sampling) 122,880 and 112,896 Mhz. The best (sonic) result I had with 112,896 Mhz. This one is an Fox oscillator, and the only one I could find at this frequency. Over 100Mhz is quite difficult to find a matched oscillator for audio use. This last one oscillator I used was definitively better than 100Mhz (max "standard") one. I do not know exactly the explanation for why the system behave better with an clock frequency that is higher than the designer of the DAC chip recommend as max frequency. A possible explanation could be that about a lower jitter for a higher oscillation frequency. Even tough this my oscillator is not a very special one, it seems to have a lower jitter than the 100Mhz Crystek one. Jitter is depending frequency as known. Anyway I have no better explanation per to day...
I think to start soon another series of experiments, with a little better control for the ESS8018 parameters, and different clock frequencies. This maybe will bring to me some more informations about how the things really works...
It could be nice to hear from another ones about their impressions/results/confirmations in using high frequencies for clocking Sabre DACs
Old 28th August 2012, 04:17 PM   #176
Coris's Avatar
See the change !!
I really think too that the shape of the signal for an clock oscillator do not matter much. It can be sinus or rectangular. The clock signal is anyway adapted inside the receiver chip in that manner to minimise errors for use in further circuits inside the respective chip. So, that sinus to be seen in your picture is made rectangular inside the ESS9018. But lower phase noise and jitter from a much better oscillator (OCXO) than that standard one used in BDP95/93, it brings for sure better results...
Old 31st August 2012, 01:18 PM   #177
Originally Posted by Coris View Post
Hi Joe
The best (sonic) result I had with 112,896 Mhz. This one is an Fox oscillator, .
I have been using Fox as well, indeed that is what I am using for 25MHz.
I still think you should try the "SAW" oscillator, as these have much higher stability and are made especially for high MHz use, indeed they can be used for making highly stable GigaHertz oscillators. The are not Xtal based, more stable and more rugged.
As we can probably agree, it is nice to get the right freq, but in this case there may be a plus even if that more ideal freq cannot be achieved.
You trusted me when I talked you into "double-clocking" the Oppo 95, maybe you could trust me on this one as well and try it (Farnell # 1907485), and they are cheap. Try it, I am keen on getting your feedback, and for the Buffalo guys out there, we may have something interesting to tell them.
Cheers, Joe
Old 31st August 2012, 03:46 PM   #178
Coris's Avatar
Yes, agree. I will try it. Just ordered. Actually I forgot to check this oscillator type out at Farnell after reading your earlier post. So, I will come back soon with impressions/conclusions...
Old 31st August 2012, 03:47 PM   #179
Bare is offline Bare  Canada
Interesting thread. Been fooling with 'audio' since '71.
Never heard even a mention of Oppo 'till last few days.. Here.
Curiously I went and googled.
These odd Rascals are cheaper than their Sony counterparts, but not seriously so.
Been down the CD and modded CD /dvd gizmo path before.. repeatedly.
Sounds were OK and slightly better after countless hours and some fairly serious coin ... but still NO threat to my ancient vinyl, clicks pops and all...sad but also true.
No matter.. as there are very few ( 2 or 3?) CD selling shops left standing Here in Vancouver. Likely a fairly representative situation, as a guess?
Who the hell ..buys ..CD's these days?? Old men I suppose?
Even More pertinently: Who in Hell Buys DVD's?? Seriously?
Frankly easier to find new releases in Vinyl than Disc.. true.
Certainly A new and improved CD gizmo has appeal as a 'New Toy'.
Hey! I'd like one ..but not for $1/$2K though
Thinking this as the Future? Now that's a Stretch
Old 1st September 2012, 12:37 AM   #180
According to the experts, conventional oscillators are "BAW" devices. These are less likely to be stable as you increase the frequency. The datasheet will rarely ever mention "BAW" as they are so by default anyway and no need to mention it - but if it is a "SAW" oscillator, they will definitely say so in the datasheet.
Cheers, Joe
New Oppo BDP-93/95 and DIY possibilities... Joe Rasmussen Digital Line Level 2 2nd June 2011 03:00 PM
Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? gaetan8888 Everything Else 0 5th April 2010 06:16 PM
Oppo BDP 83, and Tube amps ronton3 Digital Source 2 8th March 2010 10:31 PM
SONY BDP-BX2 doesn't power on yzriver Digital Source 1 24th February 2010 08:19 AM
Newest OppoDigital.com BDP-80 - opinion FastEddy Digital Source 1 20th February 2010 01:09 PM
Copyright ©1999-2017 diyAudio
