Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st May 2011, 11:54 PM   #1
Unhappy Door closes and opens, closes and opens....
Hello,
I have a Rotel RCD-951 that when I put in a CD and close the tray (ether with the open/close button or pressing on it) the tray will go in, and then come back out again. this will happen about 4 ~6 times before the CD is read, and then everything is fine. Plays perfectly. I have been leaving the CD player on, hoping that this may help, but it didn't.
Does anyone have any help on what I need to do to fix this?
Thanks in advance,
Old 1st June 2011, 12:27 AM   #2
wrenchone's Avatar
Sound like a funky/noisy open/close button that's putting out a couple of pulses per push instead of one.
Old 1st June 2011, 12:43 AM   #3
sofaspud's Avatar
I agree with wrenchone. Something's wrong with the eject button. Or maybe there's a limit switch inside that should be activated by the tray closing. Either way you'll have to open it up and check it out. Temporarily substitute the eject switch with any similar switch (probably SPST) you have handy and see how that works.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 1st June 2011, 12:43 AM   #4
Belt drive problems with loading mechanisms are very common. Listen to hear whether the loading motor stops when the tray goes in, or just peels out for a while without finally getting everything in position. The MCUs usually have some time-out before it will reverse the loading motor when not getting a good end-of-stroke indication (from mech postiion swithces) or load current goes too high. The problem is usually a belt that stretched and/or glazed. It could be something else, foreign material/dirt... but most likely a belt.
Old 1st June 2011, 03:06 PM   #5
Thank you all for your help, I will open it up and check out your sugestions.
Old 1st June 2011, 03:54 PM   #6
Thank you for all your help, I will open it up and check out your suggestions.
Thanks!
Old 1st June 2011, 03:55 PM   #7
Do you know where I can get the belt?
BBC story: 'Brain 'closes eyes' to hear music' ssmith Music 6 2nd December 2007 06:12 PM
Sony 60ES-Tape door no longer opens-Need help mike246 Digital Source 1 22nd July 2007 07:31 AM
Adire Audio closes shop. Too bad. dtaylo3 Multi-Way 18 3rd July 2007 10:30 PM
Kenwood DP3300D tray closes after opening immediately Bernhard Digital Source 1 28th June 2004 12:40 AM
Page generated in 0.08567 seconds (73.52% PHP - 26.48% MySQL) with 10 queries
