| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am looking arround to a solution for an easy to build SPDIF source select. Certainly here on diyaudiio there are a lot of threads to this topic, but I am not able to find this.
This IC could be a appropriate device therefore: UA9637 Datasheet pdf - DIFFERENTIALE VERDOPPELUNGLINIE EMPFÄNGER - Texas Instruments |
#2 |
No advices?
I have found a wide range of threads here on diyaudio, but no of them are really helpful. Here some examples: Digital input selector Digital Audio Input Selector ????? Digital source selector? Digital source switching In the attachement I have create a simplified schematic with tri-state buffers (line receivers). Therefore are a lot of integrated circuits available like the follow: http://www.national.com/ds/DS/DS34C86T.pdf http://focus.ti.com/lit/ds/symlink/ua9637a.pdf http://www.datasheetcatalog.org/data...F125_126_2.pdf http://focus.ti.com/lit/ds/sbfs019a/sbfs019a.pdf http://www.onsemi.com/pub_link/Colla...MC10E164-D.PDF Which of this ICs is to prefer, if there a reclocking unit is in use in front of the DAC and which without such a reclocking unit? |
#3 |
I'm the lowliest of the newbies here but a simple question comes to mind.
Why are you trying to overcomplicate your setup? Use a 2-poles electrical switch with as many positions as sources you want to feed to your dac/re-clock unit. An SPDIF signal is, at heart, an electrical signal running on a coaxial cable just like any other (well, except it's a digital signal but it doesn't really make a difference for this matter). I can't stress enough how much of a newbie i am with this matters, but i don't see why a simple eletrical switch tied to one spdif input on your dac wouldn't work? This other option wouldn't work with a reclock unit between your source selector and your dac, but if you want to err on the "neat" side, just use the builtin multiplexer in your SPDIF receiver, i believe most units have it. Twister Pear audio has a very good example of this layout:4:1 Receiver P.S.: I'm not 100% positive on what's the policy for external links, especially ones with a commercial side to them. If this link goes against diyaudio policies please remove it mods or drop me a PM and i will do so promptly. |
#4 |
The issue is bandwidth and impedance matching. spdif signals, unlike audio signals, are transmitted with matched source, load, and cable characteristic impedance. If there's a significant mismatch, you get ringing and reflections. Will a normal switch cause enough of a blip to have an effect on the eventual audio signal? Possibly. An RF coaxial switch would be a safer choice- they're commonly used for antenna switching.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 | |||
I have forget the attachement mentioned by post #1 - sorry Last edited by tiefbassuebertr; 23rd June 2011 at 08:46 PM. |
#6 |
Feeding the SPDIF signals directly over a mechanical rotary selector is not a good idea. However, the TPA 4:1 Mux is a neat solution; in addition, each source has its own input transformer to eliminate ground loops. You can still use a rotary selector, but it only provides the DC control signals. I have the TPA module and for me it works very well.
#7 |
Very good point, the RF switch solution is still much easier and quicker than building a whole pcb for this. Are RF switches very expensive?
The impedance of a common coaxial SPDIF cable is 75 ohm right? Are there RF switches with this impedance? i thought RF equipment was commonly 50 ohm? Thanks for your insight so far, i'm gonna be needing something like this in the near future when i decide to cough up the money for a proper dac kit
#8 | |
#9 |
Well it seems the Original Poster wants a more versatile solution, time to fire up your cad software then!
The TPA solution looks very good and i think i will pursue that way when the time comes. Only two problems come to mind: A) I quickly looked up the transformer, am i reading right? 10 dollars each? That's hefty. B) Since it's a fully digital switch happening inside the IC, can it be done "live" (with the DAC turned on)? |
| input selector | bebertattoo | Pass Labs | 4 | 21st June 2010 08:19 PM |
| Digital xover sp/dif -> sp/dif ? | TNT | Digital Source | 2 | 17th December 2007 03:50 PM |
| input selector | lawbadman | Digital Source | 8 | 10th September 2005 09:45 AM |
| Nominal heat of the input dif.pair in Aleph | marjan | Pass Labs | 9 | 5th August 2002 06:50 PM |
| Page generated in 0.11579 seconds (81.62% PHP - 18.38% MySQL) with 11 queries |
