| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Odd behavior...I posted earlier on how my cd 54 will not play unless warmed up..tonight after a few drinks i wanted to have a look under the hood..so i powered it up with disc in place from cold and it would not read TOC...so i flipped it upside down to undo the bottom i noticed that it was reading TOC...odd..not sure why?could it be something to do with the turn table? Anyone know? thanks in advance...
#2 |
Have you replaced any caps ? If this uses the Philips swing arm type RAFOC then there is a 33uf cap that is a common problem on the servo PCB under the laser.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Magneto the Gravity Man
Hi.
Mooly is correct. As this is a first generation player with the CDM-1 and TDA1540 DAC chips, the cause of the problem is most likely to be old electrolytic capacitors. As Mooly said, one of the common problems is a 33uf cap to be found on the board attached to the cd mechanism. These should be changed for IDENTICAL value caps as they are value sensitive. It is also likely that the main caps on the power supply board are also in need of changing. Remember ... if changing components, one thing at a time then test otherwise you may create a new fault and be unable to determine where it is !! It should be a very easy fix. Andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#4 |
Will start with the 33uf caps...I swapped out the 2200uf and 3300uf with no change...so next tep will be the 33uf...thanks
#5 |
Its the most common problem on these... don't use 47uf or 22uf... it has to be 33uf for this.
| Marantz CD-84/CD-74 service manual? | bleachershane | Digital Source | 5 | 4th March 2012 11:00 AM |
| FS: Toroidal Transformer 54-0-54 | theAnonymous1 | Swap Meet | 3 | 11th October 2010 11:08 AM |
| Marantz cd-54 | billbo | Digital Source | 2 | 2nd September 2010 02:22 PM |
| HELP ! How do I add a DAC to a Marantz CD 54 | lorienblack | Digital Source | 3 | 31st December 2009 09:23 PM |
| Page generated in 0.07331 seconds (75.96% PHP - 24.04% MySQL) with 10 queries |
