| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi all.
I have built a DAC using a dir9001 decoder and a TDA 1543A 16-bit DAC IC to convert the audio from my TV to analog for my old stereo system. Unfortunately, it can only convert 2 channel digital, not 5.1. I am gettin my TV via OTA, and the only audio output on the TV is TOSLINK, the reason for my project. Sadly, I can not change the audio output format on my TV from 5.1 to 2 channel PCM (dumb, right!?) so my DAC doesnt work. It works for my CD player, and my DVD player when I choose stereo output, so I know it's not my DAC. My main question, is if anybody knows of a product to convert 5.1 to 2 channel PCM for me to use between my TV and my DIY DAC... I've read alot of places that dolby has a lot of licensing on the tech, so it may be near impossible to get a chip for me to build a DIY....any inputs or ideas? Again, unfortunately, my TV will ONLY output 5.1 when gettin OTA signals. I can hook my DVD player through the TV, pull the audio out from the TV, and my DAC works because I am able to choose stereo on the DVD player. I am quite sad right now. Any help would be awesome. Ken |
#2 |
I am thinking that it should be possible to hook up an external tuner. There should be models that have a regular stereo analogue output besides the ac3/digital crap digital out. Did not research this but that would be my starting point.
#3 |
I see now you wanted digital out, in that case I would put a computer in between and use the sound cards outputs set to 2channel mode.
#4 |
There where HD tunners that had this conversion included in options... But wheren't the cheap SD, "rebate" ones.
I would look into an used digital receiver in a thrift store/cash converters/pawn store. That DAC that you have (with TDA1543) is not such a great DAC to begin with... Last edited by SoNic_real_one; 26th May 2011 at 01:15 PM. |
#5 |
ok, thanks for the input
I was keeping my eye open at the reuse stores, but havent seen any yet ![]() Ken |
#6 |
Hey, does anybody have any experience with this DAC IC? The WM8746?
DACs | WM8746 | Wolfson Microelectronics IT says it is a 6-channel DAC, and I was thinking maybe I could use this. My TV manual says it puts out 5.1CH audio via TOSLINK, not specifying that it is Dolby. Since it is not Dolby, I don't have to find some ridiculously expensive IC to handle Dolby. Any feedback would be great. Ken |
| Seismograph + digital pictures : A/D Converter | umutmt | Analogue Source | 5 | 19th November 2007 09:36 AM |
| Analog to Digital converter | amirmk | Digital Source | 9 | 26th November 2005 12:50 PM |
| digital clock and converter newb | rockstudio | Digital Source | 10 | 23rd October 2005 01:07 PM |
| Digital to Analog converter | condor655 | Digital Source | 4 | 15th May 2003 10:02 PM |
| Page generated in 0.10303 seconds (70.01% PHP - 29.99% MySQL) with 10 queries |
