| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
The bottom trace in the picture below shows the music that came out of the CD line out
of a Marrantz CD5000 which uses a TDA1549 with 4X oversampling. The top trace came from patching into the I2S lines before it gets to the TDA1549 and feeding them to the inputs of a TDA 1543 Non OS DAC. The I/V conversion is done using an opamp per data sheet. Although the 2 traces are inverted with respect to each other, one can see that the top trace is smoother while the botton trace has jagged edges. Is this why oversampling sounds so harsh? Unfortunately, I was not able to fully listen to the new NON OS sound since my CD player starts messing up once I got everything hooked up. It plays for a seconds, and stop for a couple seconds with static noises and starts again for a seconds and stops again for a few seconds with statics and over and over. I unhook all the patch cables and put the CD player back to the way it was and it still messed up. Anybody have any idea what could have gone wrong? Is patching into the I2S caused the master clock to become totally messed up? Do I need to build a new master clock? Also when I build the I/V conversion using opamp per spec, the sound is so soft. I had to replace the spec 1.2K feedback resistor with 66K to get any decent volume. The Rbias is 3.3K. ANybody knows why the sound is so soft using spec feedback resistor? Did the datasheet intend for the output of the I/V opamp to be fed through another opamp for additional voltage gain? |
#2 |
Looking at those waveforms I'd say the top traces indicate some serious high pass roll off going on. Either problems in the I-V or a really poor layout.
I think the differences between a competently implemented non-os and os DAC is not going to be enough to be grossly visible on your scope. Got access to a spectrum analyser? Hook it up and I expect you will see that the top traces have a very impared high frequency response. That may sound good for some kinds of music, but I prefer to use tone controls that I can adjust. Phil |
#3 |
If you feed the I2S lines of your CD-5000 to a TDA1543, you'll not have a non-os DAC! The oversampling is in the controller, not in the TDA1549...
Fedde
http://www.fedde.nu, gainclone and non-oversampling DAC audio projects and kits... |
#4 | |
A 66k feedback resistor is way too much!!! The 1.2k as in the datasheet should be fine as this would give you 2.3mA*1.2kohm=2.76Vpeak output, I think the problem is somewhere else in your system... |
#5 |
I did parrallel the feedback resistors with caps per data sheet.
You are right that there must be something else wrong in my system. I think the low level is caused by the fact that the data in the I2S lines are 4X oversampled as Fedde pointed out . |
#6 |
BQC,
Read following thread completely: Hint: I2S versus Jap. input format. ![]()
Rudolf Broertjes |
| NOS DAC with oversampling - anybody done it? | oon_the_kid | Digital Line Level | 66 | 31st July 2009 02:38 PM |
| what is 1x oversampling | amp builder jb | Digital Source | 4 | 25th July 2005 02:38 PM |
| TDA5141 oversampling or non-oversampling ? | Bernhard | Digital Source | 4 | 1st September 2004 10:27 AM |
| Non-Oversampling DAC | lucpes | Digital Source | 42 | 6th July 2004 03:06 AM |
| Non Oversampling Vs Oversampling | jkeny | Digital Source | 25 | 9th April 2002 07:50 AM |
| Page generated in 0.08183 seconds (78.76% PHP - 21.24% MySQL) with 11 queries |
