| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello Audio Experts!
A couple of years ago I took a chance on a used cdp, the rare & highly acclaimed Berendsen CDP1. It even has an upgraded cap or three. Really, really, sounds great! But now it is having trouble reading CDs, mostly my CD-Rs but also with store-bought CDs sometimes. It most always will take lots of time to recognize a disc. It is getting worse.... So from my readings it looks like the laser pickup might be weak. I opened the machine & greased it up & adjusted the laser power. No better. So I assume it is time to replace the laser. I think I found the right pickup, & this looks to be a fairly easy thing to do providing there are no tricks which I don't know about. Am I barking up the right tree? Is this as easy as throwing a bone to a dog? TIA! Murf PS: So like I opened my cdp, and to see what was happening better I took off the plastic crossmember that goes across the transport tray & holds the magnet disc which would sit atop the cd & mates with the drive spindle when playing . With this removed, all CDs play, even CD-Rs! If I put it back on, even without tightening the screws down, no play. Um, ideas, please?!?! pls...pls...pls.... |
#2 |
Now the cd tray won't stay closed with the top magnet off of the spindle. The machine with the magnet on is now reading only redbook, no cdr's at all.
Murf |
#3 |
I've never heard of this player... what mech and pickup does it use ?
Pictures maybe ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
The machine is pretty much the same as a GamuT, if that helps. DAC is a Crystal cs4290, laser pickup is an 'OPC-A15', I can't find any ID for the transport, on the web but it has #s GM9350, & what I figure to be the control board has Samsung chips, but no adjustment pots.
Thanks, Murf |
#5 |
Boy, I sure don't see $2000 retail in that chassis!
Looks like a Sony loading mech, but pickup # doesn't coincide. A photo with tray open & clamping support removed would help. From description, sounds like it's possible, assuming not a weirdly bad platter motor, that the probable cause is that a "press-fit" platter has slipped on the motor shaft, giving wrong focus distance. Generally, if you roll the laser to innermost position, the bottom edge of platter is usually about 1mm or so above the top of the laser plastic cover, so that cd surface is 2-3mm above lens. Just ballpark figures there, but an easy check to make. |
#6 |
The laser lens looks to be ~ a mm below the platter.
#7 |
Not at all sure, but I would guess that it is a Samsung laser(seems supported by presence of Samsung chips), very much in imitation of a Sony KSS213 type laser(though unlikely a drop-in replacement) and it's mech. The loader is a dead ringer for a Sony mech, if it's not the real thing. However, I can't at the moment think of another likely cause for the symptoms you are experiencing.
#8 |
I can't come up with much either I'm afraid.
A scope check of the RF signal is really what is required as it reveals so much. Could it be a weak spindle motor ? as it played without the weight of the clamp (if thats what you mean). A trick that sometimes works if only to prove something is to apply a 9 volts battery across the motor for a few seconds to "burn" and clean off dirt on the commutator. If you try that you must isolate the motor electrically first.
#9 |
It seems my laser does work. BUT, it is not reading CD-Rs, and it looks like the previous owner had adjusted the laser power up. The control board (?) has no adjustment pots, so I figure this stuff is working well. The laser pickup goes in & out, up & down.
Murf |
#10 |
I think all you can do is try another pickup but without detailed scope checks it is a guess in the dark.
CDR's vary enormously in how "good" the recovered signal is and are dependant on discs and the CDR burner used... again the scope confirms what is actually happening. You need to ID the pickup too.
| CD player not reading...sometimes | c12mech | Digital Source | 3 | 9th June 2009 12:22 PM |
| Aura AUC-50 (Philips CDM-9) CD reading problem | ceharden | Digital Source | 3 | 16th April 2009 08:29 PM |
| About CD reading | Sandor | Digital Source | 3 | 8th January 2006 01:59 AM |
| CD 17 Intermittent CD reading? | Jai | Digital Source | 1 | 30th August 2004 06:04 AM |
| How it works reading material for CD audio | tmd1 | Digital Source | 0 | 20th September 2003 07:38 PM |
| Page generated in 0.10859 seconds (77.68% PHP - 22.32% MySQL) with 11 queries |
