Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th May 2011, 01:10 PM   #1
Default arcam delta 170 cd transport problem
The drawer on my cd transport will not eject. The motor runs for about one second and then stops (even when under no-load conditions with the motor removed from it's cradle. If pulled out manually the drawer closes fine when the load button is pressed. Is this a simple fault to rectify (any ideas?)
Old 24th May 2011, 02:21 PM   #2
wgxold is offline wgxold  China
May be there is a small hole on the front. U can insert a paperclip to open the drawer. In fact, as times fly, this situation often happen. What I do is put an unused disk before close the drawer.
Old 25th May 2011, 06:21 AM   #3
amc184 is offline amc184  New Zealand
amc184's Avatar
When you press the eject button, in which direction does the motor turn (is it trying to move the tray out or in)? It sounds to me like one of the limit switches may not be working.
This advice isn't relevant to this CD player.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 25th May 2011, 12:42 PM   #4
When trying to eject the drawer moves about 2-3mm before stopping. Have checked limit switches and they're fine. I've just been told there are two transistors for eject and two for load and that there are a couple of diodes involved also. I have found the transistors on the pcb but cannot read their type numbers (does anyone know what they are - I'll replace all four if I can find this out). Unfortunately there is no eject hole and my daughter is scratching the paintwork on the drawer by using various implements to open it, so I'd like to get it sorted asap.
Arcam Delta 170 CD Transport dancil Digital Source 8 15th February 2010 09:36 PM
Service manual for Arcam Delta 170 Transport? Steven C Digital Source 2 28th January 2010 12:50 PM
Arcam Delta 170 + Blackbox firestorm Digital Source 17 14th October 2008 04:02 PM
Arcam Delta 290 Sound Problem phil_79 Solid State 6 10th August 2008 09:57 AM
Page generated in 0.07776 seconds (77.55% PHP - 22.45% MySQL) with 10 queries
