Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th May 2011, 03:12 AM   #1
rx7691 is offline rx7691  United States
Default Digital format of tv and cd player!?
Hi all!
This is my first time posting on this site, but up til now, it has been a wonderful tool in my projects! Right now, I am building a dir9001/TDA1543 DAC, with the main goal being to run it off the television, since it only has toslink output for audio, but I don't want to buy a new receiver with digital inputs. I have studied the manuals for the dir9001 and tda1543 in length, and have built it on a prototype board.
When I hook it up to the tv, which is a samsung LN40B500P3FXZA, all I get is what I can best describe as high frequency noise, nearly synchronized with the LR CLK signal. When I hook it up to the toslink output of my CD player (RCA RP8078), it works great!
My question: Is it possible that the two components are putting out very different forms of digital format, the TV being in an unuseable format for me? Ive tried googling what binary outputs they each use, but have come up empty handed. The dir9001 is able to lock on the PLL on the TV's signal, and puts out:
Bit CLK: 3.2 MHz
LR CLK: 48.1 kHz
System CLK: 6.2 MHz
The CD player outputs:
Bit CLK: 2.850 MHz
LR CLK: 44.1 kHz
System CLK: 5.7 MHz
The manual for the DIR9001 says it can use those specs, as well as the TDA1543.
Any help?
THANKS!!
Ken
Old 24th May 2011, 05:15 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
I think you have to go to your tv's menu and select toslink audio output or outputs.
Old 24th May 2011, 10:24 AM   #3
DF96 is offline DF96  England
Is the TV outputting some special format such as Dolby or surround-sound? You should be able to set it to normal PCM stereo, but this might not be the default setting.
Old 24th May 2011, 02:19 PM   #4
@singa, In the manual it says anytime there is audio, it is outputting data via the toslink, as evidenced by the ability of my DAC to lock on to it, so I don;t think that's it, but good thinking.
@DF96, I was wondering something similar as well, maybe it is encoding a 5.1 audio, which my chip isn't made to handle. I'll check in the settings, and see if I can find something dealing with surround sound. I hope that is all it is! haha
Old 24th May 2011, 02:23 PM   #5
Also, @DF96, PCM is still a form of S/PDIF, right? Do you know?
Old 24th May 2011, 02:26 PM   #6
SY's Avatar
That's how it works on my set- the digital output is selectable via menus for several different formats. Choose the wrong one and all you get is noise. Unfortunately, the setting for this was well-hidden in a nonobvious place in the menu, so I spent at least an hour fiddling with it the first time.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 24th May 2011, 02:31 PM   #7
@SY, thanks for that. You guys are giving me hope! haha! Unfortunately I won't be able to play with it until later this afternoon, but I appreciate the answers@
Old 24th May 2011, 05:07 PM   #8
That question is like asking if "a passanger is still a form of car".
S/PDIF is a transport medium (harware interface).
PCM is an audio encoding format (composed of digital bits). That bit format (software) can be transmitted/transported over a S/PDIF physical (hardware) connection, but is not the connection...
Old 24th May 2011, 07:39 PM   #9
Sonic, didn't mean to upset you. I'm still rather new to the whole digital world. I appreciate you clarifying that hardware vs. software dilemma in my head! I've talked with a few other people, and the common consensus seems to be that it is putting out a 5.1 signal when i need only stereo. When I get home tonight I will go through the menu on my TV as carefully as I possibly can and see if I can change this.
Ken
Old 25th May 2011, 01:18 AM   #10
Did I came out like "upset"? My appologies, just wanted to explain you something...
And yes, in USA, the "over the air" TV channles are encoded DolbyDigital, even if they are stereo (to minimize the bandwidth).
On cable, the cable boxes/receivers (not the TV) will have a setting to output the signal Dolby Digital or PCM stereo.
Personally I don't have a setting in the TV to "convert" DD to uncompressed PCM... but my TV is a Polaroid one, and I live in country with ATSC system (on air) and QAM (on cable).
Your situation might be different, didn't say if you have cable or antenna, and what country are you in (your Samsung model is sold in US at Best Buy so...?).
Good sounding midi or mini format CD player? Brisso57 Digital Source 5 25th May 2010 08:37 PM
Digital out from a CD player that doenst have one? crackerkorean Digital Source 5 19th January 2006 05:26 PM
Digital output format of Sony SACD Engine with CD? ThorstenL Digital Source 10 7th November 2004 12:13 PM
Digital in on CD player Sjef Digital Source 4 22nd September 2003 06:24 PM
converting vinyl to mp3 or cd digital format? Luke Analogue Source 11 3rd January 2003 12:58 PM
Page generated in 0.09663 seconds (86.69% PHP - 13.31% MySQL) with 10 queries
