| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have tried finding an answer to this on this board as I know I have seen it discussed in the past. My Marantz cd54 won't read a disc unless it has been powered up for 45 minutes to an hour...I know the 3 large 2200uf caps look bad other than that not sure what could be causing it...
#2 |
To me, this "warming up" is the capacitors taking their time to charge up to the required voltage, which is a sure sign of bad capacitor and imminent complete system failure when the capacitor decides to give up totally.
#3 |
I figured as much...just not sure which caps? I had plans on changing all the caps that had anything to do with heat. Like I stated earlier the only ones that look bad are the very large ones..2200uf 25v...the rest look solid.
#4 |
its should be one of the small size cap. Look for 0.22 , 2.2uF around the laser circuit.
On the CDM1 - CDM2 there is a certain cap that goes wrong search on the forum. did you get the schematic? Is it look like the Philips 303?? Service manual, eprom result list | ElektroTanya | Service manuals and repair tips for electronics experts |
#5 |
danico..
I don't have a schematic...and this one has a CDM-0....I looked under the transport and all caps look solid...bt i will get a hold of some and swap them out...Albeit, when it does warm up it plays like a charm.. |
#6 | |
it means there is a break somewhere.Download the CD63 service manual it should be similar.Try swapping the flexi cable of the laser or check the pcb board for hairline breaks and various cable assemblies.We give too much credit to electrolytic capacitors.
#7 |
Maybe this tread can help you. I know I just read about the same problem.
Extending Philips CDM4 Life?? " I repaired a B&O CD5500 version 2 (CDM4) once with the identical lowering of sampling test voltage after a few minutes. Turned out the 33ufd axial cap in the laser supply servo board was on the way out. After replacement the machine has worked flawlessly for the client with an excellent 50mv center of disc laser sample. This has been 5 years now. I've seen many CDM2 with this identical problem." |
| Marantz CD54 help ! | Zaireeka | Digital Source | 2 | 3rd March 2008 10:21 AM |
| Looking for Marantz CD94 PLAY button | oshifis | Digital Source | 1 | 31st October 2007 04:27 PM |
| Marantz CD94 doesnt play | Daveylodge | Digital Source | 1 | 24th December 2006 03:28 AM |
| Coxial Output for Marantz CD54 | lscangus | Digital Source | 3 | 29th July 2006 08:09 AM |
| aleph5: only 3 irfp240 warms up | fheanor | Pass Labs | 2 | 6th December 2004 06:44 AM |
| Page generated in 0.09345 seconds (76.63% PHP - 23.37% MySQL) with 10 queries |
