Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th May 2011, 04:54 PM   #1
Default Spdif to a lap top
hi...
i have a spdif coming out from my Xbox and i need to plug it to my laptop but my doesn't have the spdif port...
is there any thing that i can do to get the sound from my xbox to my laptop!!?
Old 17th May 2011, 06:31 PM   #2
Mooly's Avatar
Maybe,
Spdif into USB interface?
A simulation free zone. Design it, build it, test it.
Old 17th May 2011, 06:35 PM   #3
Originally Posted by Mooly View Post
i didn't understand any thing out of that thread...
is it a chip or what!!?
Old 18th May 2011, 07:45 AM   #4
Mooly's Avatar
Its a chip,
http://www.datasheetcatalog.org/data...ts/pcm2906.pdf
have you tried a google search for "SPDIF to USB" etc.... I'm sure there must be something.
Good luck
Old 18th May 2011, 09:08 AM   #5
are you sure that the chip will work!!?
also i found nothing in google
Old 18th May 2011, 11:33 AM   #6
Mooly's Avatar
I'm sure it will work as outlined in the data sheet applications... if that covers what you want it to do.
I was just trying to point you toward possible ideas etc.
Something like a cheap Mini Disc recorder has SPDIF in, usually optical but some have optical and electrical, and of course analogue out. Would anything like that do ? The analogue out could be fed to a USB convertor/soundcard etc.
Old 18th May 2011, 11:36 AM   #7
can i get it from amazon!!?
Old 18th May 2011, 01:10 PM   #8
Mooly's Avatar
Get what !
Minidisc ? The chip ?, USB convertor.
Minidisc is pretty much an outdated if brilliant and versatile format so probably Ebay for a recorder although some Sony portables I think still appear as new stock/models.
Old 18th May 2011, 01:12 PM   #9
the chip!!!??
also would the minidisc do the trick!!?
Old 18th May 2011, 04:42 PM   #10
Mooly's Avatar
I use Minidisc and as far as I know they all have at least an optical input, and some both optical and electrical. Mine is the Sony MDS-JE480.
If your Xbox outputs a standard SPDIF data audio stream then the Minidisc is simply used as a DAC to output L and R audio from it. You press record on the front (doesn't need a disc in) and you get the decoded L and R audio.
The chip would have to come from a component supplier but you just asking that suggests you don't realise the work involved... you would have to build it all yourself, make the PCB's and obtain all the other parts too... and on the DIY scale it's a major project due to being surface mount technology.
Need help with 40's lap steel field coil wiring... guttersnipe Multi-Way 4 21st January 2011 11:07 AM
Project just fell into my lap, need some advice shankroidbeast Multi-Way 20 27th May 2009 03:18 PM
Good soundcard for lap top that works with soundeasy? Jim85IROC Multi-Way 28 27th February 2008 01:09 AM
Miniature lap screened cable in twin format sbrook Parts 0 1st March 2007 08:05 PM
Miniature lap screened cable in twin format sbrook Vendor's Bazaar 0 25th February 2007 09:09 PM
Page generated in 0.08943 seconds (85.58% PHP - 14.42% MySQL) with 10 queries
