Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th May 2011, 05:32 AM   #1
Default Nakamichi AV-1 tuner intermittent popping static sound
I have bought an AV-1 receiver used about a year ago. I absolutely love this amp. It has very good weight 33+ lb..and kicks my B&W speaker very well..
Recently, it has tuner issue for several months: When I listen to a FM station for a 5-10 minutes, it lost the signal and have pop/static sound. This lasts about 10 min or so, then it picks up the signal and works again, and then pop/static,,, repeat...
I tried to get a separate tuner, but to be honest, I can't get one within my budget( 200$) that sounds better the Nak built-in tuner.
I really want have my AV-1 tuner back. Could someone help me!
Thank you so much.
PS. anywhere can get service manual?
Old 17th May 2011, 10:45 AM   #2
Mooly's Avatar
Tuner problems can be difficult.
I have never seen the Nak AV1 but would suggest you check very carefully for any poor joints particularly PSU rails to the tuner.
Look for any regulators/transistors etc in the PSU that run hot... things like that are favourite failure items on any equipment. Maybe a litte freezer spray dripped on to (not blasted at ) any suspect devices, IF amp chips etc might help narrow things down a little.
In my experience faults like this often have a fairly straightforward cause... very often PSU rail problems.
A simulation free zone. Design it, build it, test it.
Intermittent popping and crackle in LM3875 jcon2 Chip Amps 9 28th June 2010 09:50 AM
What needs replacing? Intermittent popping and clicking Stones290 Solid State 4 16th October 2009 01:42 AM
popping and static noise in an Altec 1592A lassoharp Solid State 7 14th March 2009 02:25 AM
Intermittent Static on ARC REF 3 Preamp maxzimum Tubes / Valves 18 19th December 2008 09:04 PM
Intermittent Popping...Ideas? EchoWars Solid State 16 28th June 2003 03:48 AM
Page generated in 0.06512 seconds (81.45% PHP - 18.55% MySQL) with 10 queries
