XMOS-based Asynchronous USB to I2S interface - Page 92 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th June 2012, 11:20 PM   #911
1audio is offline 1audio  United States
Its a well thought out design and supports 8 channels, which is unusual. It does not currently support external clocks but that may be a simple firmware tweak to enable.
Jitter must be evaluated as a system. Starting with low jitter is critical, but it can be "screwed up" easily in implementation. The clocks will pass through the XMOS chip in this design (although even that can be altered with firmware I hope) and a buffer on a noisy ground is all it takes to degrade SOTA jitter levels 20+ dB. Depending on the particular DAC the I2S lines may have little influence on the jitter as long as they meet the setup timing requirements.
Demian Martin
Product Design Services
Old 30th June 2012, 08:17 AM   #912
Originally Posted by Telstar View Post
I didn't try it yet.
I can't track your card due to the fact that there seems to be some problems with IT post database. Do you have any news about the delivery?
Originally Posted by bigpandahk View Post
HI Lorien
I received the waveIO today. Thanks for the excellent work. Both my Mac and Win 7 recognized it without problem.
I connect it to Ian's FIFO via I2S, I can see the "lock" LED on FIFO but the BIII does't lock. Test the signal path by Ian SPDIF and everything work fine. Any advice to diagnose the problem?
Well, I usually try to keep things simple so, for debug only, I would advice you to try to wire WaveIO I2S output port directly to BIII I2S inputs. In addition, if you are using the isolated I2S port, make sure that it's has 3.3V power applied between V+ and "Isol. GND" pins.
L
EDIT:
Originally Posted by audiodesign View Post
modules arrived!
Thank you for letting me know! I'll mark them as delivered!
Contact link for WaveIO USB-to-I2S/SPDIF board.
Daughter card GB list for WaveIO can be found here
Old 30th June 2012, 10:56 AM   #913
Telstar is offline Telstar  Italy
I got it last monday. The pcb is beautiful
I'm waiting to build the psu, as I wont even hook it up usb-powered.
I also use xxhighend player, so KS at 176.4k is very important to me as well, and I hope the 24 bit issue will be resolved soon. Til then i'll use only hardware attenuation.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 30th June 2012, 05:02 PM   #914
You didn't awnser me about latency of the asio driver and how much sample buffer it can be set without failing..
DON'T YOU UNDERSTAND.. wish people would try to understand what all people producing music do... when they sell stuff to them..
it's not only audiophiles anymore... comprende
low latency asio driver running at 64-128sample is a must
also playback with asio should take the least amount of CPU..
it actually need to compete with RME and LYNX soundcard for the asio drivers, stability and CPU usage..
Also about jitter your saying there will be jitter induce by the master clock but your XMOS board have the master clock and force you to use this one.. So i guess it depends what people used as master clock on their xmos board.. it's kinda limiting to force the use of the onboard master clock..
Old 30th June 2012, 05:09 PM   #915
Default hmmm...
It sounds like you are looking for a pro audio soundcard, perhaps Lorien created the Wave IO for DIY audiophiles, not for recording engineers? It just seems like this is not the product for you, nothing wrong with that, it just was not created to suit your use.
Old 30th June 2012, 05:40 PM   #916
USB is not ideal for low latency applications. The USB architecture imposes a minimum latency that is much higher than PCI can achieve. I believe its 1 mS. It may be possible to get it to 250 uS. This seems to be an issue with PCIe as well to a much lesser degree and may just be intrinsic to serial interfaces. No easy or even hard work-arounds. The high speed serial interfaces are unidirectional in their communications with a certain amount of time to process and react required for a full duplex communication. All of the new interfaces (USB3, Thunderbolt, PCIe, etc.) have this same architectural limitation.
Demian Martin
Old 30th June 2012, 06:21 PM   #917
@audiolic I apologies if I didn't answer to your question earlier! There are few reasons for not doing this: in your earlier duplicate post (well, almost) you are referring to a product that it's outside of my knowledge, moreover, you're upset on companies that are not willing to share those infos that you are asking about. Well, please note that I'm NOT a company, just a simple guy that loves what is doing and wants to share it with rest of those who wants to accept it.
About recordings, I want to remind you that WaveIO card wasn't built for it just for playback only! (it doesn't have I2S DATA inputs) and, speaking of latency.. if I have to reclock a thousand time all the I2S signals just to met what I believe I have to achieve then I'll do it without care too much on latency.
it is for me, according to my believes
In the end, I suggest to address your request to those who are producing the card in question or their driver's manufacturer hoping that they will answer you...
Kind regards,
Lucian
Old 30th June 2012, 09:02 PM   #918
Got my WaveIO-Board with Buffalo III and Broskie-Unbalancer working tonight...first nothing came, both the 3.3V trick did it...one question: sep. PSU for the 3.3V (as I have it today) or from the DAC-Board ? What is best practise ?
Old 30th June 2012, 09:34 PM   #919
henri47 is offline henri47  Belgium
Why should you use a 3,3V PSU? Preferably, give WaveIO a good, separate 5V low-noise PSU. You could take the 5V from the Placid, but then consider to place larger heathsinks on it. I've build a separate PSU with Belleson superregulators. It works flawlessly. If you follow Lucian's advice you can't go wrong
kind regards and success with your build
Henri
Old 30th June 2012, 10:52 PM   #920
3.3v are needs for the isolator...as stated above and i experienced this as well....
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1368 28th April 2016 04:39 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
