Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th May 2012, 07:22 AM   #851
rsdio is offline rsdio  United States
Originally Posted by 1audio View Post
UAC1 and UAC2 are enough different that the device can't switch dynamically between them. In UAC2 it seems all the communications are at high speed even for a 44.1 file. It sort of makes sense because negotiating a high speed link is a little involved and you don't want to switch once engaged. UAC reserves some bandwidth for the audio stream (what they mean by isochronous) so the audio won't get hammered by a disk transfer on the same host. At lower data throughput it probably releases more bandwidth for other transfers.
You are correct. If the Device starts in UAC1, then it probably won't even list 192 kHz as an option in the Descriptors. If the Device starts in UAC2, then it's going to require a disconnect and reconnect or a USB rescan to change to the slower bus speed of UAC1.
However, a Device can have multiple Alternate Interfaces, and that's where different amounts of bandwidth for the Isochronous endpoints are specified. So, when a UAC2 Device switches from 192 kHz to 44.1 kHz, the selected Alternate Settings will be using less bandwidth, leaving the rest for other Devices on the USB.
In other words, the USB Audio Device does not change bus speed, but it does change the percentage of the available bandwidth that it reserves and uses.
Old 30th May 2012, 10:44 AM   #852
It does indeed make sense and would also explain why the isolator doesn't work with the WaveIO. Thanks for that.
Old 31st May 2012, 01:31 PM   #853
Just DIY!
pinnocchio's Avatar
Send a message via MSN to pinnocchio
Here's something some of you without MACs will probably enjoy...!
Since WaveIO is natively supported in OSX and not in Windows, some of you probably wish they had a MAC. (I don't... )
There's a USB dongle called EFI-X (V2 or V3, older version like V1.1 only support MAC OSX to a certain version).
This dongle is capable of booting a RETAIL copy of MAC OSX as well as any other PC supported OS like Windows and Linux.
It boots MAC OSX natively (not virtualized and not Hackingtosh) from the retail original copy and installs without issues. Works like a charm but make sure you check the ACL since not all CPUs, Motherboards and GPUs are supported. But the list is pretty good. I believe it requires at least a Core 2 Duo and higher processor and maybe some AMDs as well...
I have a friend in the US using it with V2 and loves it
You can actually go to youtube and look for EFI-X
So this should make some WaveIO fans happy!
Ciao!
Do
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone
DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2
Old 31st May 2012, 03:08 PM   #854
Telstar is offline Telstar  Italy
Paging Lorien
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 31st May 2012, 03:55 PM   #855
soundcheck's Avatar
Hmmh. Most of the USB HiRes DAC users out there use the generic Thesycon USB driver under Windows 7.
Is the WaveIO not working with that driver under W7?
::: Squeezebox Touch Toolbox and more ::: by soundcheck
Old 31st May 2012, 04:00 PM   #856
Just DIY!
pinnocchio's Avatar
No, working great and it is what I'm using. Just pointing out alternatives
Do
Old 31st May 2012, 09:17 PM   #857
jrling is offline jrling  United Kingdom
Default EFI-X
Many postings suggest that it is a scam? Ripping off others' software from Chameleon et al - see here from Toms Hardware which is a reputable site - Exclusive Report: EFI-X Mac Booter, A Scam?
Must say I wouldn't touch it especially as it costs 175 Euros + shipping and also almost certainly infringes Apple's licence terms.
Old 31st May 2012, 10:57 PM   #858
Just DIY!
pinnocchio's Avatar
To infringe on Apple's licence is of course 1000000% true as just farting infringe on it and you might also get sued for iFart!
My friend uses the v2 or v1.1 and was going to get v2 on the hype. His experiences are mostly positive not saying there is not any bumps or hickups though... Like I said I'm happy with my PC!
Do
Old 1st June 2012, 12:37 AM   #859
Send a message via AIM to yammy1688 Send a message via MSN to yammy1688
I picked up Lorien's board a ways back and haven't been up to date with any new firmware/drivers. I'm still using the luckit drivers.
I looked over thesycon's website, Is the USBIO generic USB device driver the one that is appropriate for this?
Do
Old 1st June 2012, 04:43 AM   #860
Entirely my fault, I apologies for this mess; here it is (v1.56.0)!
L
Contact form for WaveIO USB-to-I2S interface
Daughter card GB list for WaveIO can be found here
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1303 10th May 2013 05:19 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 35 13th January 2012 07:02 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
Copyright ©1999-2013 diyAudio
