| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#821 | |
It may be semantic but there really is one clock in SPDIF, the one in the data stream. DAC's per se don't have clocks, they are a user of them. But your point is that the clock is not local. A valid comparison is that the Async USB clock originated at the master clock frequency local to the system instead of being multiplied up from the imbedded word clock in spdif. The classic problem is extracting it cleanly from spdif. The latest chips have some extraordinary efforts to do a better job of it. They don't use the data, but rather the header which is a more stable part of the stream. They have very sophisticated PLL's to lock to the imbedded word clock and reject any high frequency components to have a clean low jitter clock for the rest of the system. In async USB the data is actually streamed from the host and the receiver (XMOS in this case) sends commands back to speed up or slow down the rate. There is a lot of async activity going on in the XMOS to make this happen. That should be isolated from the DAC as well. I don't think Gordon has an SPDIF receiver product, he does make a USB to SPDIF converter and its very good. My point is that there are better and worse solutions, and there is not an absolute right and wrong.
Demian Martin Product Design Services |
#822 |
The source was an Auraliti PK100 and the receiver chip is a crystal CS8416. The AKM seems to have less jitter. I'll plot and provide tomorrow.
#823 | |||
Lucien,
I think it is just plug&play with a normal recent Linux machine. If it does not work with a freshly installed system, then the usual Linux path has to be walked: searching the forums, trying to find out the reason and fixing it. There is a good page here:Soundkarten konfigurieren ? Wiki ? ubuntuusers.de , but unfortunately it is in German. Main thing is to check if the system recognizes the card with Quote:
This is for Mint and Ubuntu and the like. If it is not working, it is mostly because of internal conflicts in the chaotic Linux sound system, and there should be a fix for that. Btw in no way I have a clue what I am doing I would use Windows for simplicity but for me Linux sounds much better, especially with some tweaking and/or realtime kernel. Sorry that I cannot be more helpful, for more detailed troubleshooting someone more knowledgeable should write some tutorial. But as said before, it runs fine out of the box, so there should be no reason normally. And hard to believe that there is room for improvement, but I see that you are still in the process of optimizing design. Count me in for the MK2 version ![]() And again thanks for offering this very professional and thought out work for the community of freaks here , and for the very humble and kind way you manage the whole thing.all the best, Juergen |
#824 |
Contributor
Hey Lucien,
I'm also looking to run on linux, using an Alix 2D2 and playing between Voyage MPD and looking at MPDpup(puppy Linux). Once I receive card I have to finish dac, but I will still be able to test the connection etc. This to be a little ongoing, but by all reports this is working a treat! Thanks again! Drew |
#825 | |
I promised earlier to report the results of upgrading from bus-powered to dedicated PSU with the WaveIO. Here goes. 1. My system is based on a Fit-PC2 (an industrial-quality embedded motherboard known for good USB implementation) running a USB-orientated and fairly heavily "tweaked" configuration of cMP2, an XP-based PC-audio setup that some of you may be familiar with. The Fit uses a linear PSU which was designed especially for small, single-voltage motherboards and makes a significant difference to its sound quality. The design is described here: Power supply design for low power PC The USB-to-I2S converter was Doede Douma's PCM2707-based board with Tent clock, AQVOX driver and bespoke PSU. Though now obsolete, it was considered in its day to be among the best at its price point. As noted in earlier posts, it was connected to the Fit via a ADuM4160 USB isolator and DIY cable. (BTW, note that the board, driver and isolator cost rather more than a WaveIO.) The DAC is a home-brew TDA1541A with an elderly (but IMHO rather good) Audio Synthesis I/V stage. 2. The first step was to replace DD's board with the WaveIO powered via USB using a stock USB cable but without the isolator. The connection to the DAC was made via the on-board I2S isolator. In the light of audiodesign's report that this is probably at least as good as direct connection, that's how I plan to leave it. The reason why is discussed below. The improvement in sound was marked and pretty much as Jogi and others have described. 3. I then made a 5-volt PSU for the WaveIO board, again using John Swenson's design (see link) though I used a slightly better voltage regulator. If going from the PCM2707 to the Xmos chip made for a significant improvement in sound quality, it was outstripped by powering the WaveIO with a good PSU - much improved detail and extended bass without any apparent "digital" colouration. I'd urge anyone considering running the WaveIO without a dedicated PSU (Wolfsin?) to think again. My Fit-PC2 is probably about as good as you'll get as far as low-noise USB V+ and Gnd lines go but it simply doesn't compare to the results from a decent PSU. 4. I got a small improvement by fitting a home-brew USB cable using short lengths of CAT5 cable but no screening. Note that the WaveIO works perfectly with no +5-volt line in the USB cable: I just unsoldered it and left it at that. 5. The last step was to restore the ADuM4160 isolator. Here there is a snag - I couldn't get it to work with the WaveIO even using a stock USB cable. I don't know why this is - there's nothing wrong with the isolator but the computer cannot see the WaveIO with the isolator in circuit. I repeated the test on a different computer with the same result. Any guidance would be appreciated. In short, my take is that the WaveIO is a very fine product but that it benefits from proper implementation. Others (though not the designers of products using the things) frequently argue that asynch protocols make things such as fancy power supplies for the digital side of things unnecessary. My experience is that this is not so. Last edited by Ryelands; 26th May 2012 at 12:37 PM. |
#826 |
Which one?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#827 | |
I second Ryelands experience with power supply, it does make a difference. But even bus powered I had no urgent feeling to tweak anything, even less so now with separated PS. And that is a very good sign, as I normally feel the solder itch right from the start , especially with digital stuff.Ryeland, if possible, try a Linux system, it is even possible to run it from USB stick or create a double boot system, so you can use both. I found especially XP very mediocre, to put it mildly, even with Asio and many tweaks. |
#828 | |
In addition, the header variations are selected based on the data in the previous word. So, while you say that the latest chips don't use the data, they're still affected by the data because every header starts with a rising or falling edge based on the previous data. Thus, the clock errors (propagation delays on output) are data-dependent and there is no way around it. I agree that SPDIF should be retired except where needed as an adaptor to old designs. |
#829 |
"In addition, the header variations are selected based on the data in the previous word. So, while you say that the latest chips don't use the data, they're still affected by the data because every header starts with a rising or falling edge based on the previous data. Thus, the clock errors (propagation delays on output) are data-dependent and there is no way around it."
I do not pretend to be a digital engineer, and certainly my understanding of such things is in no way complete, but I once had an SPDIF receiver approach explained to me which may actually decribe "a way around it". This theoretical receiver would use software to compare the header to theoretical "perfect" patterns, and then select which of the "perfect" pattern the header is representing, rather than trying to measure the leading/trailing edges directly: thus avoiding edge measuring errors, and errors in the edges. If I understand the explanation of how the SPDIF reciever in the ESS chips works, they appear to be using an approach somewhat like what I have attempted to describe. In any case, I prefer to avoid SPDIF when possible in favor of an async USB receiver and close coupled I2S to the DAC, rather than jump through unnecessary hoops trying to re-invent the wheel. |
#830 | |
In other words, the "compare and select" process in software would take longer time than the actual timing errors that already exist in the clock. |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| Ultimate USB to I2S interface | sampler | Digital Source | 206 | 30th January 2012 03:45 PM |
| Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface | minidsp | miniDSP | 35 | 13th January 2012 07:02 PM |
| Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? | cxhawk | Digital Source | 7 | 3rd December 2010 02:30 PM |
| interface I2S with USB | mermoz | Digital Source | 0 | 21st February 2003 10:34 AM |
