| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#391 | ||
)!Quote:
) must have been via PMs etc.With enough digging I'm sure we'll find a way. I bought a smart (programmable etc.) charger as well and lost interest but perhaps I should restart my research. It'd be nice to have everything done automatically.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones |
#392 | |
However, I believe there are some chips which only reference the master bit clock, while other chips reference both the bit clock and the word clock. If the latter, or any variation like that, then you really need to know which clock is the master and the consequences of other signal being late. However, the general principle with multi-signal serial links is that all the signals should be updated slightly ahead of the clock so that the clock can reliably read the other signals. Maybe if you can point to a circuit example of how you would align the non-clock serial signals to the DAC clock then I would understand what you're trying to accomplish. EDIT: Also, if there is another critical signal besides the clock that I'm missing, then please mention it. In my estimation, if you have a critical input that isn't aligned, then you've not successfully distributed the DAC master clock back to the driving circuits. Last edited by rsdio; 18th February 2012 at 02:37 AM. |
#393 | |
Sidly, on the other site has a very good DIY CDP digital section that is a good example for a schematic and a good read if you are interested in alternatives to the modern all-in-one wonder chips. But we're getting off topic For this thread the key indgrediant is somehow moving the masterclock(s) to the right. Diyers can figure out the rest. |
#394 | |
Meanwhile, a pure digital filter should be immune to jitter because it should process the data and not the clock. The only class of filter that reacts to jitter on its inputs would be ASRC, which should be avoided in a properly-clocked DAC system. I'm not saying there's no place for a digital filter, just that the problems you describe should be avoided rather than hacked around. |
#395 | |
Hey at least we agree ASRC should be avoided ![]() I think we are confusing each other when referring to a DAC, sometimes meaning the complete unit and other times meaning the dac chip. Forget about my experiements with the old chips, Probably the xmos isn't the best for those anyway. All they need is a single clock for rbcd typically 256xfs=11289.6 (instead of the 2 512fs clocks on the waveio.) I am also slowly tinkering with a fairly modern chip the WM8741. Do you know if there will be truncation with the I2S format? Does the WaveIO output 32+32 word length I2S or is it the standard phillips 24+24 I2S? I know the WM8741 has a few dither modes but don't think it can dither past beyond the 24th bit. I think only the Sabre's, new AKM, and new BB can handle 32 bits without truncating? Last edited by regal; 18th February 2012 at 10:07 AM. |
#396 |
On another note.,
in the USB Audio Class Driver Control Panel., the Stream Formats are both grayed out, is it the same for everyone who is using this driver ?. Sure would be nice to see the Input and Output Stream Formats functioning., thanks for your taught s on this . regards reo |
#397 |
My Stream Formats are grayed but output of 2 channel, 24 bits is correctly displayed and nothing is displayed for input. I believe this is functioning correctly. There are no other options for WaveIO with the revision I have.
'gardz, Dick |
#398 |
So, made a cheap box for trying the spdif transport capabilities of Waveio and connected to the (also very cheap) PSU with JLH Ripple Eater...
![]() ![]() ![]() Tried with ASIO in my Audio-GD NFB-12 and worked flawlessly... Brought my inexpensive dac another level, I must say... If also a cheap DAC like that can have such an improvement, a Buffalo and I2S connection are coming next! ![]() Thank you, Lucian!
#399 |
#400 | |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| Ultimate USB to I2S interface | sampler | Digital Source | 206 | 30th January 2012 03:45 PM |
| Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface | minidsp | miniDSP | 35 | 13th January 2012 07:02 PM |
| Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? | cxhawk | Digital Source | 7 | 3rd December 2010 02:30 PM |
| interface I2S with USB | mermoz | Digital Source | 0 | 21st February 2003 10:34 AM |
